Question about Honeywell Heating & Cooling
MY HEATER IS NOT WORKING ACCESS PANEL MIGTH BE BAD
  • 149 Answers
Are you describing a furnace blower door. those switchs do go bad can be jumped out-make sure you turn off power to furnace before proceeding remove wires splice the two together wire nut tape connection and make sure wires can not be sucked into the fan blower they can be ordered easilly online. replace when new sw. comes in
Posted on Jan 31, 2010
My 2004 jeep Liberty hood release is stuck it won't go back and can't get it to release hood what should I do
get it serviced...
in a shop they migth.
1: remove grills and panels in fender to gain acess to the cable
then with 3 people (yes)
1: pulls the handle.
2: other pulls side if the cable. at above found easy access point
3: other tries to lever hood open with plastic pry bar.( gently)
if that dont work the latch must be attacked directly, grills off.
Dec 17, 2016 | 2004 Jeep Liberty
Samsung Plasma 42" TV Screen problem
panel migth be bad, connection/connector on it might have loosen up already! it it has a warranty then return it at once and ask for a new one! its what you've paid for.
Nov 18, 2007 | Samsung SPN4235 42 in. Plasma HDTV
The heater works in my Duraflame Electric stove heater DF1-3108 but the flames wont display. There is no separate panel in the back of the unit to access a light bulb. Can you help?
There may be an access panel in the front for the light? You might have to have a good look for a panel that can be removed. Make sure its unplugged before getting into it.
Nov 19, 2016 | Heating & Cooling
Hello my question is, when i turn on the swticth to turn on the ac/heater nothing comes out. what migth be the problem?.
U could try turning if on high and smacking the fan with a rubber hammer under the passenger side dash, if no go, try checking for power and ground at the fan motor, if you have no power to the fan check for power at the fan speed resistor, then finally check for power out of the switch, always check all your fuses prior to troubleshooting electrical problems , it will most likely be a bad fan motor, then the switch, then the fan speed resistor please rate
Jul 31, 2011 | 2001 Ford F150 Styleside SuperCrew
Right and left rear turn signals randomly quit working and then return to working condition. Is this a loose wire, bad bulb, or a bad flasher unit?
it could be any of them.you most star by checking the wires they may not be making contac or a loose ground do the same with the bolt and use some electronic grease to avoid rust. finaly check the relay in the fuse box it migth getting hot,good luck
May 18, 2011 | 2006 Chevrolet Uplander
Freezer developing frost while the fridge is warm
The frost build up is causing airflow blockage to fresh food compartment. Frost build up is either a sign of poor door seals, door left open, or bad defrost circuit. If after manually defrosting and after a few days the frost reappears, problem most likely is with the defrost circuit.
If you have some background of electrical circuits you may attempt repair yourself or call in a tech.
Defrost timer on your unit is near the light in the refrigerator. Recessed in a hole, turn with a flat blade screwdriver and advance timer until you hear a click and refrigerator turns off. After a few minutes the heater should come on and should hear moisture hitting heater in freezer compartment in back panel.
If heater is not coming on, could be a bad heater or defrost thermostat is bad. Both of the parts are accessed through the back panel inside of heater. Unplug and ohm check for continuity of heater & defrost thermostat. Heater is a cal rod unit, thermostat more likely to be the problem. part #5303918202
Jan 30, 2011 | Frigidaire FRT21P5A Top Freezer...
Heater fires up burns for 8-10 seconds then shuts down then attemps to restart one time then completely shuts down and then the service heater light turns on.
Most Common problem with gas pool heaters is the pressure switch, in order to test it you need to open front access panel and disconnect the pressure switch which the sensor connected to the end of a brass tube, touch the ends together in order to bypass the pressure switch, if it works as normal when doing this then it is just a bad switch, very easy to change. Costs about 30 bucks.
Nov 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Ice build up In GE Tnx22brcalbb stops fan from circulating air.I can remove the ice and freezer will work for several days but ice builds up again.
there is a problem with your defrost circuit.you also need to check for any bad spots in your seal that maybe letting air in the freezer causing excessive ice build up.but you need to check your defrost sensor
Feb 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
From work when I go to face book and it says "site under construction" If I go to someone elses computer or access it from home there is no problem. How can I get my computer to acces it.
if you are shure that you enters facebook at : http://www.facebook.com then your work network migth be blocking facebook.
Try this: go to http://www.guardster.com/subscription/proxy_free.php and enter www.facebook.com in the field called Adress. this will give you an "undercover connection" (its not illegal) to the site you want to visit, and it migth not be blocked by your network.
please rate my solution:)
Feb 19, 2009 | Facebook Social Network
Heating & Cooling Logo
23 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
