Question about Dometic Rooftop RV Air Conditioner
I have a 2007 duo therm ac in my trailer with a heater opption on the selector switch what do i have to do to make this opption function
  • 128 Answers
If the unit thermostat only says heat,then its a heat unit that will be controlled by putting it in the heat position and adjusting the thermostat to a position that will activate(lets say about70 degrees) to kick the unit on OH! and make sure the propane bottle is open.If the thermostat says heat pump or heat strip,then it is that.
Posted on Nov 02, 2014
  • Dometic Master
  • 6,674 Answers
Most times the heat strip is an option that can be installed but is not currently installed. If you check your owners manual, there should be a model number of you AC unit, or you may have to remove ceiling grille, and get model number off the bottom of the upper unit. There will probably be 2 sets of numbers, one for upper unit, and one for the lower unit where the controls are. Write them both down, and get back to me, and I'll see what you have, and what you'll need to get it working. You can try heat setting and see if any heat is felt, just to be sure it isn't already there. You won't get a lot, just slightly warmer air, as it's won't heat entire trailer, but will take a little bite out of the air. Also when/if you remove grille on ceiling, look for a heating coil in opening when exposed.
Posted on Jan 31, 2010
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
I have a 247 03 Springdale RV trailer. I want a
Depends on wattage demand of ac unit. VXA=W 110x20amps=2,0200 Watts. A 2,00 watt generator is too small. Best go for a 3,kw genset. A 5 kw will leave you room to run appliances and the ac simultaneously., otherwise you will need to watch your margin usage. I think 4.5 kw gensets are also available. Happy trails.
Jul 25, 2009 | Heating & Cooling
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
I have a 2000 ford E350 van with front and rear air. the front blower motor runs at low speed, The front blower still runs on low even when the knob is set on medium or high. I do not know where the...
it's either the blower motor switch or blower motor resister. Resistor ?Heater Blower Motor Switch Removal Remove the battery (10655) ; refer to Section 414-01 . Remove the battery tray. Remove the screws. Remove the battery tray. Disconnect the heater blower motor switch resistor connector. Remove the heater blower motor switch resistor (18591). Remove the two screws. Remove the heater blower motor switch resistor. ----------------------------------- Switches Removal Disconnect the battery ground cable. Remove the center trim panel; refer to Section 501-12 . Remove the control assembly. Remove the screws. Remove the control assembly. Remove the A/C-heater function selector switch knob. Disconnect the vacuum harness connector. Disconnect the A/C-heater function selector switch connector. Remove the A/C-heater function selector switch. Remove the screw. Remove the A/C-heater function selector switch. Remove the temperature control switch knob. Disconnect the temperature control switch connector. Remove the temperature control switch. Remove the screw. Remove the temperature control switch. Remove the heater blower motor switch knob. Disconnect the heater blower motor switch connector. Remove the heater blower motor switch (18578). Remove the screw. Remove the heater blower motor switch. ----------------------------
Mar 31, 2009 | 2007 Ford E-350 Super Duty Length XLT
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Heater option disappeared
This link may help you identify what you need. What year is your trailer, & AC unit. Have a model # handy ?Have you checked your operators/owners manual ?
http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66938
Aug 10, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
174 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
