Question about Tiny Computers B1996 19" CRT Monitor
Keyboard not working properly
After installing windows xp keyboard functions dont work the same as before ie having to press arrow up button on left between caps lock and ctrl key plus the 2 key to achieve the symbol @ can you please help as its causing a bit of confusion thanxs e-mail matthew.mccreath@talktalk.net
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
My R31 Think Pad was running very slow and trying to fix this problem a technician istalled a new version of Windows XP but the keyboard is disconfigured now since some keys do not correspond with what is...
Troubleshooting keyboard issues ThinkPad Lenovo Support US
Internal ThinkPad Keyboard
Power on your computer. At the BIOS splash screen, press F1 on your internal keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
If you are not able to enter BIOS, try pressing the blue ThinkVantage button or press the Enter key.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your internal keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
Check to see if you have installed any keyboard mapping software that would be interfering with normal keyboard functions.
Boot into Windows Safe Mode and test keyboard functionality with notepad. Please refer to step "B" above.
Windows XP Safe Mode instructions:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx
Windows 7 Safe Mode instructions:
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Verify that the latest BIOS for the ThinkPad system is installed.
Click here to view the latest BIOS files for all ThinkPad systems.
Reseat the internal ThinkPad keyboard, if applicable.
If the keyboard is a customer replaceable unit (CRU), then reseat the keyboard connector. Please verify this in your system's Hardware Maintenance Manual.
If these steps have not solved your problem:
Refer to "Need more help?"
External USB Keyboard
Ensure that the keyboard's USB cable is securely installed into your ThinkPad.
Remove the keyboard's USB cable from your ThinkPad and install it into a different USB Port.
Power on your computer. At the BIOS splash screen, press F1 on your External keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
Try entering BIOS with your Internal Keyboard.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your External keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
Windows XP Safe Mode instructions: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx
Windows 7 Safe Mode instructions: http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Jun 09, 2011 | IBM 02K6212 for ThinkPad R31 Series...
Arrow key problem
I think you are using multimedia enabled keyboard. So check it properly, there must be some software utility installed on your system for this keyboard, use that, as it seems that the keys are fixed as shortcuts for those programs. So remove those.
Apr 30, 2010 | Compaq Keyboard
Logitech MX 600 mouse - left side not clicking
Try holding both buttons down, switch off, switch on. Worked for me.
Sep 09, 2009 | Logitech MX 600 097855036162
The mouse on Dinovo edge keyboard not working at all
It is possible that your touch-disk is turned off. Try pressing the Fn key (RHS of the space bar, between the alt and ctrl keys) along with the "right mouse button" (the right button underneath the touch disk) -- when you press the Fn key the word "On" will light up above the button.
If that is not the problem, perhaps the driver software was not properly installed or the keyboard is defective. You could try reinstalling Logitech's software.
Good luck.
- Les.
Mar 26, 2009 | Logitech diNovo Edge 9676850403 Keyboard
Logitech LX8 Mouse back button quit working on AOL
This has been a long time problem with Logitech and Aol. If your mouse software allows you to edit your mouse buttons, change the back button to "keystroke" and enter the back arrow key on your keyboard as the command. Alt left arrow also works. While you don't appear to have a forward button, Aol users who do, would change it to "keystroke"...Alt right arrow.
Mar 09, 2009 | Computers & Internet
Dell wireless adapter for Windows XP Media Centre can not find keyboard
The first thing to do when you have a hardware problem is always to go to Device Manager :Start>My Computor{left klick on My Computor}>Properties>Hardware>Device Manager.In the drop down,find your device that is giving you problems.Double klick on the device and see what Windows says about it ,whether it needs drivers or has a physical problem.Your USB adaptor seem to be working OK since it is oscillating ,meaning that it is searching for the Keyboard transmission to lock on.This means that you have loaded the correct driver software for the usb device.I suspect that your problem is with the Keyboard power-make sure you have installed the batteries correctly{polarity check}When all is working properly,you should find the keyboard listed under Keyboards in Device Manager.Double klick on it to see if it is working properly.Your USB device should appear under USB Controllers.Regards
Jun 07, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Tiny Computers B1996 19" CRT Monitor Logo
Top Tiny Computers Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
