Question about Canon PIXMA iP4000 InkJet Photo Printer
Black ink leakage - Canon PIXMA iP4000 InkJet Photo Printer
  • 159 Answers
Most likely there is (or was) ink on top of the sponge. When this happens the hydrostatic pressure gets messed up and the cartridge will leak ink until there is no more ink on top of the sponge. Look at the side of the cartridge, there should be a small gap between the sponge and the top of the cartridge. If there isn't you can place paper towels on the egress hole and wick out the excess ink to fix the problem.
Posted on Feb 02, 2010
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Acer Aspire One D255-2670
The black ink is NOT showing empty but it will not print
Firstly two things here assuming everything is fine with your printer.
Firstly have you changed the options in the document or picture youre trying to print? For example, if printing a document from Word, go to printing options and click advanced then print in 'black/white' rather than 'color'.
Secondly when you installed the ink cartridge in the printer, have you removed the plastic/paper sticker attached which protects the circuits and ink leakages?
good luck,
kc
Feb 23, 2011 | Konica Minolta Magicolor 1600W Printer
Black ink is dripping from bottom of printer
this problem is the possible reason for the cartridge leek. Please check the cartridge for possible leakage
Oct 15, 2010 | Dell 946 All-In-One InkJet Printer
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
The cartridges were changed is it possible that something is wrong with the interface between the cartridge and the printer? Also what would cause the slow printing? What is causing my hp6940 deskjet...
I have never believe in refill cartridge, because there is always a chance of leakage of the ink. I believe that what happen with your printer.
Dec 21, 2009 | Computers & Internet
IP4200 leaks line of black ink on back of pages
There is a fix, design flaw as you say. You need a new ink absorber kit which includes a mylar strip so it won't happen again. What's happening is the waste ink from the purge assembly is pumped over to the center of the absorber pads and when it dries it stops the flow and it backs up thru the exit rollers.
Sep 30, 2009 | Office Equipment & Supplies
Black ink leaking from bottom of printer!
There is a ink resovier where the cartridges are cleaned of excess ink after a job. That gets filled over time and gives you the leakage described. Very messes job to clean it.
Sep 10, 2017 | HP Photosmart 3310 Printer
INK LEAKAGE ON PRINTS
I need more specific info. Where is the ink: on one side only or all across the page. On the top only or all down the page. Does it look like smudges or spatter.
Aug 17, 2008 | Office Equipment & Supplies
I need help
Remove the toner in the printer and clean the printer where the toner reside. Don' t use water or any liquid just use tissue paper or cotton cloth maybe there is debris or clogged ink . Because sometimes the toner ink is leakages or stack in the roller of the toner
Apr 15, 2008 | HP LaserJet 1010 Printer
Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Oct 08, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
65 people viewed this question
old marine
old marine
