Question about Nokia E51 Cellular Phone
The phone keeps asking for voice prompts
When connected to the in-car system, which is mounted in a helicopter, the phone keeps saying, at regular intervals, "no voice prompts" (or something similar - it's not very clear). We don't use voice prompts, so is this a problem, and can we stop this?
Thanks,
Howard
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
Can't find sync on my lumina 520 phone?
First of all, turn your car on, and have it in park...
Push the Phone icon on the steering wheel. In a moment your center console (or display) will show Phone Menu, then Phone Redial... use the seek arrows on the steering wheel to move through the Phone Menu. When you find "Add a Phone" or "System Settings" then push OK on the steering wheel (or on the console). Scroll to Add Bluetooth Device, push OK. You will hear the Voice say "Push OK to begin pairing a device." Push OK, the console displays a 6-digit PIN.
Now go to your phone, to the settings, be sure Bluetooth is turned on, and then Search for Bluetooth Devices. In a moment the IP address may show but wait until it displays "Sync." Tap this tab and a second screen appears, and it prompts you to enter the 6-digit PIN form the dashboard, then push OK on the phone. In a moment the SYnc system will acknowledge the connection and ask additional questions. Push OK to conform and OK again to "Activate 911 Response," "Make Primary Phone" and "Download Phonebook." Watch you phone, it may have a screen (or two) pop up that what you to confirm to "Always Connect" to Sync (check the Yes) and then OK on the phone. When all is finished downloading (may take a couple of minutes), it will display Download Complete. Then push and hold the Phone icon on the steering wheel for a a few seconds and release. The Sync system should be up and active. Push the Voice button (the icon with the mouth & sound) and it will sound a tone and state "Sync, state your command." Then say "Phone" and the system will come back and say "Phone, state your command." Then either say "Call + (contact first and last name)," If it understands it will say "Calling (Contact Name) and begin dialing. Or say, "Dial," and the system will ask for you to say the phone number. It will repeat the number, if OK, then push the Voice button and say "Dial."
For more information, see this Ford Sync weblog: Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Cell Phones
Trying to retreive messages and now it's saying invalid number. used to I would just dial 115, then promted to put in 115# and would get message. Now just says invalid number. How do I fix this. ...
115 is the port the voice mail is on. The prompt is "enter password then #". The password is your voice mail password from the extension you're calling from. If you are trying to get your messages from another phone, press #6 * and your extension. It will then ask you for your password to your voice mail.
There are FOUR system manuals and TWO manuals for the TVA or TVS voice mail system. None of them say 7731 on the face of them, so post back with you KSU and Voice mail models.
Carl
Mar 26, 2011 | Panasonic KX-T7731 Corded Phone
How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • Oct 04, 2010 | Samsung Hue (SCH-r500) Cellular Phone
    Unable to leave voice mail, says good-bye
    I don't think the voice mail is going bad.
    On my 4424D+, I can turn off voice mail.
    I use this feature when I'm gone for an extended period of time so I don't come back to 100 VMs.
    Dial into your voice mail.
    Choose the prompt for Call Answer Mode. (Option 8 on my phone.)
    Then choose the prompt for Record Mode. (Option 1 for me.) This allows callers to record voice mails on your line.
    Feb 17, 2010 | Avaya 4412D Corded Phone
    Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
    I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
    http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
    Linking to UConnect – Required for First-time Use of Each Mobile Phone
    To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
    • Press the Phone icon button to begin
    • After the Ready prompt and subsequent beep, say Set Up Phone Pairing
    • When prompted, after the voice or beep, say Pair a Phone
    • You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
    • For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
    • You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
    Making a Phone Call
    • After the Ready prompt, say Dial
    • The system will prompt you to say the number you wish to dial
    Making a Phone Call Using Your UConnect Phonebook
    • After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
    Terminating a Phone Call
    To end a call in progress, press the Phone icon button. All calls in progress will
    be terminated.
    Phone Redial
    • After the Ready prompt, say Redial
    • The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
    Answering or Rejecting an Incoming Call - No Call Currently in Progress
    When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
    UCONNECT
    CHRYSLER GROUP TECHNOLOGY 17
    Dec 29, 2009 | 2005 Chrysler Pacifica
    Unable to connect voice dial
    Hi marrick,
    Voice Dial:
    Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
    1. Press the Accept Button (1) for 1 second.
    2. A voice dial beep will be heard on the kit to prompt the user to say the voice
    tag of the contact to call.
    3. Say the voice tag exactly as how you recorded it.
    4. The voice will be played back to you, and then the phone will dial the number automatically.
    Her's a .pdf file of the user manual, which you can save to your computer:
    http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
    Hope this helps :)
    Season's Greetings!
    Chris (ziraffa)
    Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
    Voice Mail
    If you go to Menu/Messages/Delete Msg, it should take care of it.
    Mar 26, 2008 | Lucent Merlin Legend MLX-20L Phone
    Delete old voice mail - program new voice mail
    You can usually access the system voice mail setup from any extension.
    Press Speaker
    Dial ext 200.
    When asked for security code, dial *,2,# (dial it twice if there is no code).
    When main greeting begins, dial 632.
    Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
    Follow voice prompts. Remember, 1=Yes, 2=No.
    Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
    Nokia E51 Cellular Phone Logo
    46 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
