Question about DIGITECH Music
My rp90 digitech had stopped ..once i plug the electricity the led screen writes 88 and all the leds lights and it does not change or operate to the presets what can i do
  • DIGITECH Master
  • 5,603 Answers
Check the power adapter. It sounds like it is the wrong unit or it has failed and is not producing the correct voltage.
Posted on Jan 31, 2010
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
I have a Digitech wammy 4 v pedal the led light are going out i have 3 lights left how can i fix the led light the pedal works fine with out the lights
Check the burned out LEDS with a 3 volt battery- a computer bios battery works well for these.
If they do not light, which is likely, just replace them with similar sized units. You can even change their color too. Measure the voltage at the LED sodler pads to see if it is more than 3 volts, if it is, add a resistor to drop the voltage and limit current to the replacements. Digikey sells them, and they ship around the world http://www.digikey.com or Mouser, Both are based in the US, I am not sure what Mouser's international shipping is. http://www.mouser.com
If there is no voltage at the LED pads, look for bad solder connections, or burned out resistors. If the few remaining LEDs still operate as they should, the level meter chip "should" be okay.
Feb 14, 2012 | Digi-Tech Music
My rp90 reads out pd when i plug it in and is stuck in this pd mode and doesnt let me play anything how do i unstuck it from this pd mode
Try a factory reset. This is the procedure
1. Press and hold the Store button while powering up the RP90.
2. When the display prompts you with FR, release the Store button.
3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds.
4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
May 14, 2011 | Music
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Jan 13, 2011 | Music
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
My DigiTech RP90 expression pedal isn't working at all
If you are getting no display after you try powering up properly check the plug end of the power supply with the supply plugged in with a volt/ohm meter. You should get a reading of 9volts. If you don't ,your power supply is not working. Sometimes the wire breaks where it goes into the supply and sometimes where it goes into the plug. Your power supply jack may be broken where it is soldered to the circuit board. If the unit has power you can do a factory reset. The procedure is on page 34 and 35 of the owners manual that you can download for free here:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Let me know if this helps.
Nov 26, 2009 | Music
All the LED's come on and it does nothing
Have you seen this:http://www.digitech.com/products/Vocalist/Flash_Demo/VocalistLive2_Tutorial.php
Oct 15, 2009 | DIGITECH VOCALIST LIVE 2
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Music Logo
495 people viewed this question
Top DIGITECH Music Experts
steve cannon
Level 1 Expert
noel
noel
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
