Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
No picture but still has sound. switch off and picture comes back
My 40" has been ok but now has fault. TV works fine then you loose the picture, but still have the sound. Turn the TV off for a while then the picture comes back. There is no consistency it happens radomly. Generally however once switched off for a while the picture will come back. Any ideas?
I haven`t got a solution, however mine has just started to do the same. can you let me know if u got the problem solved. thanks
Posted on Mar 14, 2010
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
My screen goes from a normal picture to a green screen with lighter green horizontal lines. Ocassionally, it will switch back to a normal picture, but lately it is taking longer to do so, or it...
Hello
The fault to this Trinitron TV is loose soldering ofcourse. Check all the soldering points at the video output card, which can be located at the base of the picture tube. Normally the components fitted on this board will heat up while working, and repeated heating and cooling will make the solder terminals of the componets to get loose contacted. Just pull out the CRT base board from the CRT causiously without make a damage to picture tube pins. Look for any loose solderings at this board. It is quite difficult to detect these loose solder points as some of them will be microscoppicaly small and can be seen with the help of a magnifying glass. Just do what we do at service table. Just resolder all the suspected solder points by applying a little more solder, without making any solder bridge short between adjecent solder terminals. In most cases, nearly 85%, the fault will be cleared out with this process. Check the plug in connection wire [comes from main board to picture tube base board] for any loose connection. Just pull it out from the main board, and reinsert it for at least two times. If any loose connections to this wire connection, this will clear out it. OK.
Aug 26, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
Hello, I have a LCD TV. MITSUBISHI Mod. #LT-40133, the left side of the tv. when the tv get hot (after 30 or 40 minutes) show vertical lines that cover almost all the left side. We replaced the Logic...
Hello
The fault can be detected from your problem post itself. When you hit at the back of your TV the fault disappeares, means there is some soldering loose or socket loose inside it. Normally, these faults will come appear after the set will got heated. The soldering points will get loose contacted, after some time, especially the solerings to the terminals of components, which will heat up durin working. This is normal fault to all kind of TVs. Your TV no also sufferes to this fault.
To determine which board and component is loosley contacted, just open your TV, and hit the top of components [verylightly with some non conductive material like plastic scale or so] , while the TV is working. Switch on your TV after opening its back cover, and wait for some time, say 20 minutes or so, and do this. From this you can determine the dry solered component. After detecting it, switch off the TV and take the board out, turn it upside down and resolder the suspected soldering points by applying a little more solder; without making any solder bridge in between adjecent soldering points.
This will surely resolve your TV's problem. If you want anymore assistance, please feel free to get me by Fixya.
If you want to get me, please post your comments after 9 hours from now, otherwise the post will go to an other, and I can't answer it. OK.
Jun 08, 2011 | Televison & Video
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
The picture is fine but the sound is not working. I push the volume and you can see where the volume level is going up. Have tried turning it off and unplugging it to try to reset it but nothing has...
Hello
Picture being Ok, and no sound output, means there is some problem inside the sound output circuit of your TV. It may be due to a speaker fault or an IC fault. You have to find out which of these has fault.
You just place your ear very close to the speaker side, and switch on your TV with its AC mains On-Off switch, not by remote control handset. Listen carefully, whether there is any sound output of any form comes out of it or not. If there is no sound at all you can determine that the speaker may be out, not in all cases. If you have the habit of listening your TVs audio by using a headphone, continious in-out action could damage your TVs headphone socket. If the headphone sockets' contact got damaged, no sound output will come from it to the speakers. Suppose you can hear the sound through your headphones but not throuhg speaker, means that its change over contact has some trouble. You just do this first. Insert a headphone pin into your TVs headphone socket, if provided, al listen to it for sound. If there is no sound from headphone also, Sound output Ic iside your TV has damaged, or not getting proper voltage to it. If there is sound through the headphone, and not from TVs speaker, trouble is related either speaker or the above said socket.
If all the above has no effect, that is no sound either from headphone, of from the speaker, you should go into the circuit board of your tv to get the fault.
Open your TVs back cover, and trace for the sound output section. There will be an Ic used as sound output. Check whether it getting heated some time after switch on the TV. If it overheats without any sound output, it is damaged Desolder it out from the circuit board, go for a same type and number, replacing it will solve the problem. If it doesn't overheat, or no heat at all, check its input voltage. In some cases, loose soldering points on the legs of Ic may also the cause. Check it too. Ok.
If you need any more clarification, ask me through Fixya. Give
a brief explanation about what you have done so far also.
Nov 04, 2010 | Symphonic ST419E TV
TV has sound,but picture not clear and in black and white. Model P42W46X
Is the picture "snowy"?
- I mean is the signal weak?
If so, check your aerial cable has not come loose at the back of the TV.
If you have another TV, or can bnorrow one from a friend/neighbor, plug this into your cable and see if the picture is ok. If so, you have a tuner fault in your TV & will need to call an engineer.
If not, then the fault is with your cable co. or outside aerial, (whichever system you have plugged in there).
Nov 17, 2009 | Televison & Video
Goodmans 17" LCD TV always sound, intermitent picture.
Give little spray of W-40 contact cleaner in Scart, seems has lil dust / rust.
Aug 02, 2008 | Goodmans Televison & Video
Goodmans 32'lcd tv
Hi Craig.
Ok are you saying that it runs with no picture & sound is ok ?
Or does it run with both sound & picture then go to standby.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Televison & Video
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
244 people viewed this question
Henry  Thomas
Henry Thomas
