Question about Bosch Axxis WFL 2060 Front Load Washer
There is a loose earth wire in washing machine where should it go?
  • 619 Answers
If it is a green wire then attach any where to cabinet. Do not connect to any source of power.
Posted on Jan 31, 2010
Can some one tell me where the earth wires go and the rest of the plugs on a fisher and paykel washing machine mw511
If you are not sure of the wiring contact an electrician!
Connect each wire to the correct terminal. Slacken the screw and push the bare wire into the hole. Re-tighten the screw. Make sure the terminals are tight and that there is no bare wires or loose strands of wire showing. It is often easier to push the pins up slightly when connecting the wires.
  • Brown - Live
  • Blue - Neutral
  • Yellow and green - Earth
Older appliances may have different colours:
  • Red - Live
  • Black - Neutral
  • Green - Earth
Nov 23, 2014 | Fisher and Paykel Washing Machines
Washer wiring diagrams
Heating element, washing motor and bearing must be earthed.
Dado
Sep 02, 2014 | Electrolux EW1200i Front Load Washer /...
Ground leakage detected device cut the power
Take wires out of plug and the wire from the connecter box of machine. With multi tester test earth to live and earth to neutral. If there is a short circuit it will show on which wire it is. Next disconnect live and neutral wires from motor and run test on all wires. If no short the motor is faulty and test the motor connectors. If the short is not found the motor is not the problem but the control system. Disconnect all wires from controls and test everything isolated and individually.
Apr 16, 2013 | Washing Machines
Earth cable had snapped off sort that but found a loose blue wire don't no were it connects to?
There should be a wiring schematic glued to one of the panel on the machine. See if you can find it and trace the wires. Otherwise get me what kind of machine it is, the manufacturer, model and how old it is.
Jan 13, 2013 | Washing Machines
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
When i switch washing machine on it fuses all electic items in house
What you probably mean is that it kick out the earth leakage in the house. You could either have a neutral wire that has shorted to earth or water has gotten onto your circuitry and is enough to kick out the earth leakage - which it is supposed to do. Try drying out the electrics of the machine with a fan heater or a hair dryer for a while and see if that solves the problem. If not do a check from the neutral wire to earth with an ohm meter and see if you get a reading. If you do, you will have to trace all the wiring looking for the leak. If the drying out solved the problem, you need to look for a water leak.
Mar 27, 2011 | Indesit Washing Machines
When i switch my washing machine on it trips the elrctricity
hello theres a bad earth on the washer could be number of things. 1 the interlock on the door 2 circuit board fault 3 motor gone down to ground 4 bear wire touching the metal part of the washer. you will some 1 with an insulation tester to do a test also with power off check the plug socket for loose wires and the washer lead for splits or loose connecton hope it helps
regards
shaun
Mar 13, 2011 | Hotpoint First Edition FEW12 Front Load...
Green wire on back connects to what
A green wire is usually an earth wire and connects to the frame of the machine. Follow the wire and if it connects to anything else that is part of the frame or casing of any component or the earth wire to the outlet, connect it to a convenient earth screw or stud. If possible, check it for continuity to earth before you reconnect the machine to the mains,
Mar 04, 2011 | Washing Machines
Changed main belt in machine and need to know
check earth wire is on motor, heater element and if metal tub fitted then this will be earthed aswell
Feb 16, 2010 | Electrolux AWW1017 Front Load Washer /...
Indesit washing machine trips ELCB when starting
DO NOT RUN WITH EARTH DETACHED.
take rear bottom panel off, take wires off heater and tape up and see if fault goes away. if so heater is faulty to earth
Nov 15, 2008 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
