Sharp 36in tv
Tv shuts down by itself,then i bang on the back then replugit back in run my hand on the picture tube to create static.then works for awhile.thanks
  • rekjr Feb 18, 2008
    thanks ed your the best
  • tim spurlin Mar 12, 2008
    i have a tv that works perfect for awhile then i guess when it gets hot it shuts off by itself then after awhile comes back on then back off/on...what could be getting hot that could be replaced
    Novelist:
    Champion:
  • 211 Answers
Your problem may well be a loose connection ( cold solder joint ) on the printed circuit board. A person would need to disassemble the set and remove the printed circuit board so that you can view the soldered side. Look for any connections that may be loose or discolored ( the color on all the soldered places should be a shiny silver color ). When you have located these area or places that seem to be different or loose, resolder them with a soldering iron, and electronic solder lead.You set should be fixed. Good luck and I hope this has helped.
AS A NORMAL PRE CAUTION, ALWAYS UNPLUG THE SET BEFORE OPENING OR REMOVING THE BACK
Ed
NC Electronic
Mills, Wyoming
Posted on Feb 18, 2008
  • Ed Meshechek
    Ed Meshechek Feb 18, 2008
    Thank you for the fine comment. Have a great week.
    Ed
    NC Electronic
    Mills, Wyoming
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Eight year old TV with a lot of miles. TV will turn on but for only about five seconds, then it will shut itself off and won't allow me to turn it back on unless I unplug the power and wait a few minutes,...
Make a fist bang on the tv frame bazel,see if u get a picture flashes?Most of these tv problems for an old CRT-(tv tube) design,tv have cold solders joints alots.If used like years in years out tv in used daily.U have a soldering iron,a roll of solders,can u do basic soldering also? Yes.Take the tv aparts resolder the FBT-the flyback tranformer,that the big black block of plastic with a red wire with a cap hook to a CRT-(tv tube).Also resolders the video board,that the board connect to the CRT-(tv tube) those pins sockets keep the video board and the CRT-(tv tube) together.Tv should be working again,if get these two soldering places parts resolders,FBT-resolders for stable tv high voltage.Video board pins sockets resolders for better joints connections between the video board and the CRT-(tv tube) connections.
Feb 03, 2011 | Sharp 27F543 TV
Sharp tube tv 1998. Comes on momentarily, then picture fragments starting at top and bottom at same time. Final indication is a thin bright horizontal line across mid tube, then internal circuit breaker...
The most likely cause of the issues is bad electrolytic capacitors.
Not worth fixing IMO.
Tracking down and replacing the caps would be many hours work...
Nov 20, 2017 | Sharp 27SC260 27" TV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
No picture or sound
It sounds more like a shut down circuit problem if you can feel static from the face of the picture tube after it tries to start up. There are several things that can trigger a shut down condition on TV's. For instance, if there is no vertical deflection signal present, the set may shutdown to prevent a permanent line being burnt across the front of the tube. If the power supply wasn't regulating the B+ voltage properly, it would shutdown to prevent damage in the horizontal sweep section. Or if the horizontal deflection circuit was defective and allowing the high voltage to climb too high (say above 33,000 volts) then the sensing circuit would trigger a shutdown event. If any of the above sounds like gibberish to you then you will need to take the set to a professional for repair.
Nov 24, 2006 | Sharp 36U-F810 36" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
