Question about PfaFF Sewing Machines
I have a Pfaff 1222E sewing machine which needs a new motor
I have a Pfaff 1222E sewing machine about 30 years old that needs a new motor Apparently they are no longer available in Australia where I live but I wonder if anyone locally has a discarded machine with a second hand motor
You can get your motor re-wound, a lot of service agents will be able to get your motor re-wound for you, they normally come up 80-100% new, and cost a lot less than new machine.
Posted on Sep 26, 2011
  • 255 Answers
Good for you, to repair a great machine instead of buying some more modern, disposable machine!
I found a generic motor that will fit your machine at http://www.pfaffmachines.co.uk/partsDB/index.php?function=detail&recordID=185. Free delivery within the UK, but that doesn't help much, does it? There's several places in the U.S., like http://www.a1sewingmachine.com/parts.html http://www.sew4less.com/QuickSearch.php http://sewingpartsonline.com/
You'll probably need to look for a generic motor for your Pfaff, but they should be out there.
I did check eBay; they do have generic sewing machine motors, but unless you're very experienced with eBay, I'd be very careful there.
Check with your local sewing machine dealer/repair place (even if they don't carry Pfaffs). Maybe they can help.
Good luck--I wish I could be more helpful, but let me know if anything I've sent helps, ok?
Robbie
Posted on Jan 31, 2010
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
I have a pfaff 1222E machine and it is sewing very slowly, is there only one speed?
Most likely is is seized due to lack of regular oiling. If this is the case, AVOID trying to run the motor until the issue is addressed or the motor may be damaged.
Wheel on right side that controls the needle up and down is very tight...
Jul 15, 2017 | PfaFF Sewing Machines
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
Pfaff 1222E machine not working right
Skipped stitches means a bent or dull needle or improper needle for the fabric being sewn. Try a new needle of the correct type for the material being sewn. If this doesnt correct it, then it will be a timing or needle to hook problem and should go to a qualifed dealer for repair.
May 06, 2010 | Sewing Machines
I need a service manual for Pfaff model 1222e
You can download it from PFAFF service manuals in PDF formats. It may not mention an E or an SE after the model #1222 because the difference is just the motor rating and different feet it came with, the rest are all the same.
Feb 01, 2010 | PfaFF Sewing Machines
Can you get me a Pfaff 1222E motor please? Th
You will need a Pfaff dealer or go direct to the manufacturer or even go on ebay and try and purchase a similar model which may be cheaper thanh a new motor and you can then swap motor over.
Jan 31, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
596 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
