Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
There is water leaking from the bottom of my machine. its not the drain pipe but can't find my manual to see where the filter is. could that be the problem many thanks Sue
  • Hotpoint Master
  • 3,463 Answers
Unlikely to be filter leaking.
Carefully check the door seal for a split or hole in it, it is easy to miss a hole, so examine it closely.
The filter is located inside the large black hose fastened to bottom of drum.
Hope this helps.
Posted on Jan 31, 2010
Getting codes in this order F20 5d and F21
The F21 code is because the machine is taking longer than the 8 minutes it's supposed to take to drain. A few things can be wrong: First, unplug the machine. 1. Check the filter (remove bottom panel and twist off the round filter). Remove any debris and put back the filter. The smallest amount can block the impeller at the drain pump. 2. Make sure the washer drain hose isn't more than 8 inches in the drain pipe. 3. use a snake in the drain pipe to remove any blockage.
If there's water in the tub, you'll need to drain that by either two ways 1. set washer to drain and spin or 2. let the water out when you check the filter (this gets messy and can take awhile to get all of the water out). Before anything, get a copy of your machines instruction manual. It's usually located taped inside the bottom panel. If not, then you'll be able to find it online for free. You'll need the model number and that's inside the washer door.
Dec 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My dishwasher isnt rinsing the dishes, leaving soap on dishes. Also doesnt seen to be draining well, leaving scum on the filter on the bottom. Tried a dishwasher cleaning agent and have tried CLR. I didnt...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 25, 2011 | Dishwashers
1. Water is leaking out from the bottom of the machine. 2. Also, wanted to know if you are suppose to manual pipe in water for this model........................thank you.............ong
The first part is that you need to check at the following for leaks.
1. Check for leak from the inlet due to poor water connection. check leak at the inlet valve.
2. Check for leak from the tub.
3. Check for leak from the drain pump/valve or the drain hose.
The second part is not clear but a connection for water and an outlet for drain is needed.( make/model not seen.)
Feb 19, 2011 | Washing Machines
My Bosch Classixx (about 10 years old) dishwasher won't fill The problem has only started since I pulled it out and cleaned! The programme sounds are as normal but no water enters the machine. I detected...
Check you dont have a small inline filter inside the inlet water pipe. Either at the "tap" end or can be on the machine itself. They look like a small sieve. Remove it and clean with a toothbrush. Then put back.
Apr 05, 2017 | Bosch SHU9915UC Dishwasher
Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Feb 09, 2009 | Select Brands Washing Machines
Leaks water out of the bottom of the machine.
check the pipe the drain hose goes into. if this is blocked the water will overflow out of it. or there could be a split in your drain hose
Jan 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint WD860P - F5 error
Remove lower rear cover of washer, locate and remove large black hose to bottom of tub.
Remove and clean plastic filter located in the hose, check pump for blockage, refit filter and hose , and test for leaks.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Inlet/ drain light keeps flashing
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
Jul 12, 2008 | Miele 24 in. G665 Built-in Dishwasher
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
82 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
