Question about Insignia IS-LCDTV32 32 in. Television
Color change ! year old tv, a color turn to black and white, sometimes have to turn off to get back to regular color.
It sounds as though you may either have a bad video chip or a tuner problem. To make for certain you don't have a cable problem, disconnect the cable from the set and reconnect it. ( a looses or bad cable line could also cause the picture to turn to b&w). I hope this helps in some manner. nfortunataly, with a problem like yours, there are many possibilities that could be a factor.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
