Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
My pump, used to pressurise the water in the house, keeps coming on every 2 mins approx even though there is no water being used in my system. I have checked for leaks and am suspicous that the pressure detection mechanism in the pump is faulty. How can i check this ?
  • 990 Answers
If you have valves at the pre tank you can run it till it shuts down then close the inlet valve and the outlet valve. Wait and see if it goes on again. If so you have a problem in the pressure tank or the switch mech. If not open the outlet valve and wait. If it starts you have a leak somewhere in the house. If not open the intake valve and see what happens. If it kicks on then you have a problem with you check od backflow valve. If this is a shallow well pump it could be in the supply line also. Good luck.
Posted on Feb 01, 2010
Testimonial: "Simple logical explanation and elimination instructions. Thank you"
  • Kieran Ruppert May 13, 2010
    It's hard to say what caused the problem. When the pump dosn't prime after 24 hours it shuts down till reset. when you pulled it off you shut down all power. This reset the pump so it will run now but the orignal problem may still be there.
I had the same problem. By design this pump turns on when the pressure in the house drops below 29psi OR when there is flow through the pump. It doesn't turn off due to pressure, it turns off when all flow through the pump stops. So, the Grundfos tech rep said my flow sensor is bad and they would sell me a new one for $75. I elected to buy an new pump ($420). Recently, I tested the old pump and it is now working!
Posted on May 13, 2010
2000 chevy corvette changed water pump and therm bubbling through rad cap
there should be no air in the cooling system and the system can be bled by using a pressurising equipment . Ensure that the thermostat is placed in the motor the right way with the body facing the hot water (head or block). Air defeats the purpose of having a pressurised cap and system.
Jan 01, 2014 | 1998 Dodge Ram 3500 2WD
My 94 Buick keeps overheating
Check to see if your fan is coming on. if it is then check the middle of your radiator if it is cool while the outside is hot you have plugged radiator
Aug 02, 2012 | 1994 Buick LeSabre
Temperature needle indicats car is hot even though no leaks and car is full of water
what is the temp? is the radiator fan operating? The fan wont come on until approx 225f
Jan 01, 2012 | 2001 Cadillac DeVille
GE WBVH6240 front load washer runs on 38 min. of the speed wash cycle then stops and door unlocks at 18 min. Tried to restart via the drain and rinse cycle at 18 min., the water pump comes on but no spin...
Hello, Welcome to FixYa.
The first thing I'd suggest is removing the filter in the pump you spoke of and insuring the pump is clear...there may be alot of water though so hopefully you're close to a drain or have some buckets/towels handy.
If that fails to resolve the problem it could be a plugged or faulty pressure switch. Have you run a system diagnostic yet ?
Here's how and the subsequent code meanings...in the event you don't know...
Let me know if any of this helps or perhaps you cannot read it, It is all included in the service manual I can send via email if you could use it.
Good luck.
Regards,
Macmarkus :)
May 06, 2011 | GE WBVH6240F Front Load Washer
Water pressure has dropped off with pressurised water system
hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
May 10, 2010 | Grohe Chiara Neu Lavatory Centerset ...
Driving my bmw e39 535i temp all fine accelerated up hill blew radiator top hose off and removed radiator to find bottom of rad also expanded now put another rad in but after 2 mins of running top hose is...
your cars radiator hose is building excessive pressure because the coolant / water could not circulate freely on your cooling system thats why its overheating, try removing the thermostat valve first and observe if it makes a difference, if problem is the same it could be the water pump is the culprit. try eliminating the easy things and less expensive approach first before deciding to top overhaul the engine of your car. a broken head gasket is not enough reason wont blow off your top radiator hose.
Apr 06, 2010 | 1998 BMW 5 Series
Engine overheats while driving approx 20 mins - does not overheat in idle - radiator was changed (new)due to leak, thermostat is new and is installed correctly, new cap as well-could it be water pump? it's...
Check to see that the electric fan is coming on, there are two fans on this vehicle. The sender for the fan is right in front of the engine near the water housing, and is a common problem. Good Luck.
Sep 16, 2009 | 1999 Jeep Cherokee
Water keep refilling
Hi my name is joyce
you have a water valve problem just as you suspected its not shutting off your water when its supposed to it is just continually letting water come in your machine, also if you are on a well system check the back of your machine where your lines come into your machine their is a wire mesh filter that protects trash from getting into this valve, but sometimes it gets through this, so just uncrew the pipes and check this. I had this problem, if you dont have a filtration system on your house I would stongly recomend one to prevent this from happening again. I have a well and this has been a problem for me.
let me know if I can help with anything else,
joyce
Feb 05, 2009 | Washing Machines
Leaking water
Are you losing water from the radiator or expansion tank and need to keep topping up? Did the fault occur before the radiator & thermostat were replaced or only since?
Sep 09, 2008 | 2001 Jeep Grand Cherokee
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
817 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
