Question about Sony FV120 Microphone
My microphone doesn't work on pc.need driver or install or something else?
Sony viao VGN z5 microphone doesn't work
Update the microphone's driver.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Sony VAIO VGN-Z520N/B Laptop
GigaWARE USB microphone doesn't work with PC Windows 10. Why don't drivers come with the product?
the microphone might not need usb drivers to work
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Aug 04, 2011 | Computers & Internet
I have hp pavilion dv1000 computer. i was using skype v3 for two years with no problem. then i installed skype v5.3. Since then my microphone doesn't work. It looks like some setting got changed. I...
I think you are right.
Try changing your audio-settings, until your mic works again.
I've you still need help, i can remotely control your computer to fix this problem
Good luck,
DJ Skywalker
Jun 19, 2011 | HP Pavilion dv1000 Notebook
Built in microphone wont work
try re-installing the driver.
it's a bit complicated, but if you could figure out what kind of microphone you have i could get it for you.
right now try googling your computer make and model, plus "microphone driver"
it should come up with a link to download something, then install that if it looks trustworthy enough.
Apr 16, 2010 | Computers & Internet
I have dell inspiron 1318 with windows vista but my my microphone does not work ? if this laptop contain the builtin microphone then why it is not working ????
You'll need to download the driver for your microphone.
After you've tried that then there's something wrong with it.
Feb 09, 2010 | Dell Inspiron 6400 Notebook
Won't work with microphone
Make sure that you have the latest audio drivers from your motherboard manufacturer's website. That will usually fix the problem.
Sep 27, 2009 | Dell Dimension C521 PC Desktop
Dell XPS 420 not recognizing microphone
Try the microphone on another system to verify it works .... if it does then repost
May 24, 2009 | Dell XPS 420 PC Desktop
I CANNOT GET THE MICROPHONE WORKING
This could be due to several reasons -
> Faulty microphone (something could be wrong with the device, or the input jack) - Try using your microphone on a friend's PC. If it is working fine, then proceed to the next line.
> Incorrectly installed sound card - Have you installed the sound card and its drivers correctly? Update your sound card's drivers, and then give it a try with the microphone.
> Go to Control Panel->Sounds and Audio Devices. Go to Audio tab, and in the Sound Recording  section, check whether your sound card is selected. Click on Volume button here, and ensure that Microphone is "Selected". Do the same with the Voice tab too.
Dec 25, 2008 | Computers & Internet
Cannot install audio drivers for hp compaq c733tu
I have an COMPAQ Presario C700 bought in India actually it is a Compaq C733TU
Follow the following steps in order
1) Intel Chipset SM Bus Controller: get it from Intel Site Search ”infinst_autol.exe” or “INF Update Utility” for Chipset 9xx (I think it is 945 or 965) on google .Search for Intel Chipset Identification Utility to know you chipset version. Don’t download or install the Zip version of the INF Update Utility
2) Video Drivers for 965 Express Graphics “win2k_xp14311.exe” “intel graphics driver win2k_xp14311.exe” you can download the latest version of Intel Graphics Depending upon your Chipset version.
3) Unknown device in device manager is actually (check properties of Unknown device has something like ACPI\HPQ0006 as one of the details download drivers which I am sharing) HP Quick launch Button Software no need to download the whole stupid software. The driver is just 11 KB while actual download of the full thing is 20 something MB
I shall upload it to some sharing site or put your email below as reply
http://rapidshare.com/files/137560123/HP_Quick_Launch_Buttons_Driver.zip.html (here is one link only 6KB zip file scan it )
4) Install UAA: You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver [“sp32395”] install this do not unzip and try to install
Microsoft Windows XP SP2 Universal Audio Architecture Update (Q888111):::::::This is what HP calls it
Here is the link for UAA: ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32395.exe
5) Audio Device is sp34200 is Conexant Hi-Def audio unzip using WinRAR or 7 Zip (execution of SP34200.exe doesn’t work) (The mike doesn’t work for me)
URL : ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse
sp34200 folder and the double click the V32 folder. Select the .inf file, click open and Continue with the onscreen instructions.
6) Modem is “sp33890” HDAUDIO Soft Data Fax Modem with SmartCP : (execution of SP33890.exe doesn’t work) unzip using WinRAR or 7 Zip
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
1.Right click on "Modem device on High Definition Audio Bus" and click Update driver.
2. Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to install"
4. Click Next and then select "Modem" from the list.
5. Click Next and then click Have Disk.
6. Click Browse to C:\sp33890 folder and select the .inf
file and click open and Continue with the onscreen instructions.
7) Wifi is Atheros AR5008 Wireless Network Adapter (not sure but it works) “Atheros xp32-6.0.3.85.zip” 370 KB
“11a/b/g Wireless LAN Mini PCI Adapter II”
http://www.atheros.cz/download/drivers/ar5008/xp32-6.0.3.85.zip
I couldn’t get the mike to work……….i don’t use it anyway
Good Luck……..
Feb 02, 2008 | Compaq Presario 700 470024-192 Notebook
Sony FV120 Microphone Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
