Question about Baumatic 23 in. BT62 Gas Cooktop
My baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
  • 619 Answers
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Posted on Jan 31, 2010
BAUMATIC GECE6005Induction cooktop will not unlock so how do I get it off lock
Baumatic GECE6005 manual page 18
To disable the safety lock feature, you should press the safety lock button for a couple of seconds. The "L0" symbol will disappear from the timer display and you are then able to use the hob in normal operation.
Sep 08, 2016 | Baumatic Cooktops
The ignitor on my AEG gas hob keeps firing. I have not spilt anything on it.
Take the switch buttons off and use a hairdryer to blow dirt out and dry up any damp. Also make sure buttons go up and down cleanly.
Mar 03, 2011 | Baumatic 27 in. B67 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Gas hob sparks when off
heatman101
Feb 15, 2010 | Baumatic 20 in. BWK1 Gas Cooktop
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Baumatic 23 in. BT62 Gas Cooktop Logo
1,615 people viewed this question
Top Baumatic Cooktops Experts
Rod Doney
Rod Doney
The Vanguardian
The Vanguardian
Pete
Pete
Level 1 Expert
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
