Question about Sharp AR-M700N Copier
HI , AFTER REPLACING ALL MAINTANANCE KITS INCLUDING DRUM AND DEVELOPER, THE MAIN CHARGER IS GETTING DIRTY ONLY AFTER A FEW THOUSAND COPIESTHUS CAUSING DIRTY COPIES, AND WE NEED TO KEEP CLEANING THE MAIN CHARGER DUE TO THIS PROBLEM EVERY SO OFTEN. DO YOU KNOW ANY SOLUTION TO THIS PROBLEM. THANKS ANDREW
  • 33 Answers
The red seals at the edges of the drum are leaking it seems part numbers on request
Posted on Jul 20, 2010
Print gets black too much
Are you getting alot of background? If so then the developer is overtoned & needs to be replaced. If you are getting black lines then that is caused by the main charge being dirty, upper fuser roller needing to be replaced due to wear or the drum is "lined" out or the drum blade is warped.
May 01, 2014 | Panasonic Workio DP-3520 Copier
MAINTANANCE M2 MINOLTA BIZHUB 163
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old.
Jan 31, 2013 | Minolta bizhub 180 Black and White Copier
AR5518-WHEN UTURN IT ON IT BRINGS MASSENG 2 AND THENF,THEN IT ENDS THERE
Your developer got spilled you have to replace your drum, developer, main charger, cleanining blade together itwill be better other wise replace your developer and main charger together
Jun 09, 2011 | Sharp Office Equipment & Supplies
One side light print
Change your drum, developer, main charger, and cleaning blade together, you will get your problem resolved,before changing all these clean your main charger may be your problem will get resolved rate this and vote for this.
May 21, 2011 | Sharp Office Equipment & Supplies
Toshiba estudio 167 - time for maintanence appear so what can i do??
hi
you need to replace some parts on the copier (consumables)
KIT - 2340 Developer Maintenance Kit - Kit Includes: Drum Blade, Recovery Blade, ( 2 ) Drum Picker Finger, Main Charge Grid, Main Charge, ( 2 ) Transfer Separation Wire, Developer - Genuine Toshiba Part -- resells for about $240 , youc an buy this at any online store .. example , http://www.precisionroller.com/maintenance-kits-for-toshiba-e-studio-166/details_57969.html please rate me 4 thumbs up
Dec 29, 2010 | Toshiba E-Studio167 Copier
One side of the drum picks up the print from other documents and smears the print on to fresh documents. How do I clean the drum?
You don't clean the drum. You either need to replace your maintenance kit , or my better guess is your using generic ink sticks and you need to use the sticks xerox makes for the machine.
The problem is that your not getting effective cleaning from you maintanance kit
Feb 26, 2010 | Xerox Phaser 8400 Laser Printer
Extra line on copies
if you are feeding the paper through the document feeder... then the rectangular **** glass is dirty... clean it...
if you cleaned that and it still shows lines... do a drum refresh...
still lines... developer refresh...
if still lines then clean charger... still lines... replace charger...
still lines... replace drum
Dec 17, 2009 | Office Equipment & Supplies
When printing backgroud is grey
Causes
Print density setting.
soluitons
The print density may be set too high. Try adjusting the print
density. For details refer to the printer's operation guide.
Causes
Defective drum surface potential.
soluitons
If a drum unit which is known to work normally is available for
check, replace the current drum unit in the printer with the normal one. If the symptom disappears, replace the drum unit with a new one
Causes
Defective main charger unit.
soluitons
Replace the main charger unit
Causes
Defective developing roller (developer
unit).
soluitons
If a developer unit which is known to work normally is available for check, replace the current developer unit in the printer with the normal one. If the symptom disappears, replace the developern unit with a new one
check ifyou want service maual you can send mail to anantakumarjena0@gmail.com
Oct 30, 2009 | Kyocera FS-2000D Laser Printer
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Sharp AR-M700N Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
