Question about Maytag MAH6700AWW Neptune Front-Load Washer
Door won't unlock
Neptune washer door won't unlock. i pressed the on/off button and waited--no luck. we unplugged it and tried again-no luck. clothes stuck in washer
  • 1 more comment
  • Lisa Freedman
    Lisa Freedman Feb 18, 2008
    thank you very much, that worked, at least the clothes won't be getting smelly now i just need it fixed which will be forever cause it's in warranty
  • Lisa Freedman
    i got the door open
    washer has power, door lock light was on. i'm going to leave it unplugged for an hour or so and see what happens. there was a loud humming sound coming from the machine, pump or motor maybe bound up
  • Lisa Freedman
    it was draining
    it's the pump, i can tell when i get near it, i think maybe something is stuck in it. my brother said maybe a sock got in it
    he's going to come over and see if he can get it out for me.
    thanks
    President:
  • 1,314 Answers
Pull out the dispenser drawer push down on the tab remove the drawer and there is a cord you can pull to unlock the door pull on the door same time you pull the cord
Posted on Feb 18, 2008
  • 2 more comments
  • robert samples Feb 18, 2008
    is it getting power
    and is the door lock light on
    what cycle is it on un plugging rarely helps is it displaying any codel
    1. Disconnect power supply to unit.
    2. Remove Back Cover.
    3. Remove clamp and Drain Hose.
    4. Remove clamp and Pump Hose.
    5. Remove wiring connector6remove three 13mmbolts securing drain pump to base
    7. Remove screw securing Drain Pump to bracket.
    Twist Drain Pump clockwise to remove.
My cabrio washer won't unlock lid, dU error, can see a piece of clothing that is stuck through the glass lid, what do I do?
Sounds like the clothing is creating too much pressure on the door and giving you a door lock error. Unplug the wash machine and wait a few minutes, then, while pushing in on the door to overcome the pressure caused by the stuck article of clothing, have someone plug the unit back in. If you've done it right and pushed hard enough, the latch should unlatch.
Dec 29, 2014 | Washing Machines
Door will not unlock neptune washer model MAH9700
you will have a flap on the bottom right hand side flip it down and get your self a towel and a bowl and a saucer put the saucer just under the pump you will need to start to unscrew the pump screw slowly and close it so you can keep emptying the saucer in to the bowl ok onece all water is out of the pump you can open the door ok please make sure the machine is swicth off be for doing any thing ok
Oct 19, 2012 | Maytag Neptune MAH9700 Front Load Washer
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you unlock the door
The problem is due to faulty door switch . If the switch is bad, washer will remained lock and the washer won't run. Try unplugging it for an hour, press and hold start button for 5 seconds, release, wait 10 minutes, and plug back in. This method resets the washer and unlocks your door.
Thank you !!
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
826 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
