Question about Ovens
Door does not close completely. Light stays on
  • 111 Answers
Weight on door, hinge got bent, door out alignment, light stays on,you can try to bend the hinges back, but i'd suggest replacement
Posted on Jan 31, 2010
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
Our oven is about six years old. It works well except that (1) the oven door seems to not close well so as to leave the light on inside, and (2) the digital display is totally out and does not display the...
Your oven door may have a defective hinge or simply is not aligned correctly. I am assuming the door, when shut, is NOT totally sealed around all four sides??? If the door is sealed around all four sides, than you have a switch that activates the light that is possibly defective. As for the electronic display, this display unit will have to be replaced.
Thank You,
Please accept
Jan 28, 2010 | Ovens
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Door will not stay closed completely
if the seal is meeting the frame it will be ok, if there is a gap allowing air to escape then the frame itself may have been bent at some pric
Aug 10, 2009 | KitchenAid 27 in. Built-in...
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
88 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
