Question about Ford Radiator To Fit Compact Tractor 1700
Ford 1700 Tractor - flushed radiator, repalced all hoses and cap...loose radiator fluid at overflow near cap when running tractor.
  • 47 Answers
Sounds like your getting preasure into the water system check conpresson on the cyl.s
Posted on Feb 10, 2010
I have a Ford 1500 tractor that is running hot. I have flushed the radiator and changed the thermostat, it runs hot when the pto is under a load. Any suggestions?
check the water pump that its working properly belt is tight and fan able to pull air through to coils of radiator and radiator cap is working correctly also may have to do a full flush of system --- also check oil if needs to be changed and if oil is ok not milky which would indicate a gasket blow by
May 22, 2016 | Ford Cars & Trucks
How do I replace my radiator in a 1996 Buick Regal 3.8 3800series
This is actually not too difficult.
I recommend replacing the upper, and lower radiator hoses while you are replacing the radiator if they are getting old.
1. Disconnect the battery.
2. Remove radiator fan (Some had two 10mm bolts at the top, and slots at the bottom, others had two more 10mm bolts on the bottom.) - And unplug the electrical connector.
3. Disconnect transmission lines (you will loose a bit of fluid)
You may also have two engine oil cooler lines that need removing (Also may loose some oil)
4. Remove upper and lower radiator hoses, and the overflow jug hose.
5. Unbolt radiator (should have two 8 or 10mm bolts connecting it to the radiator support near the top of the radiator)
6. Pull radiator up and out.
7. Reverse for reassembly
8. Refill radiator, I usually leave the top radiator hose loose while filling to remove air bubbles in the engine. - reconnect upper hose when fluid starts to get close to the radiator inlet. Some of these engines have a small brass air bleeder near the thermostat housing to accomplish this in a different way. Also fill the overflow jug about half way.
9. Check transmission, and engine oil. - Run engine, and watch for any leaks. - Recheck antifreeze just to be sure. Obviously don't open the radiator cap when the engine is hot.
Feb 10, 2015 | Buick Cars & Trucks
How do i change the radiator fluid?
Most radiators have a drain plug on the bottom tank the engine block also has a drain plug . Remove the radiator cap ,open both drains ,let all the coolant run out, if there is no radiator plug remove the lower hose , remove the heater demister hoses, with the heater control on hot flush out all the coolant from the heater radiator. with a garden hose, till the water runs clean, tighten the radiator plug or re fit the hose,put a garden hose into the radiator and flush out till the water at the block plug runs clean ,refit the heater hoses, refit the block plug, fill the radiator from the hose leave the cap off , If it has a overflow tank clean and flush it. start and run engine for 5 minutes top up radiator if needed . stop engine and drain out all water. most important that all old coolant is drained out, only buy the best coolant you can . If you make up your own use only distilled water. keep some to top up with never mix with another brand. Fill radiator with coolant top up over flow tank, run engine top up coolant as needed, refit radiator cap run for another 10 minutes check for leaks,
Oct 14, 2014 | 2006 Chevrolet Trailblazer
Radiator overflow leaking
The cap can be at fault can happen any time check radiator every week . Have the cap and radiator pressure tested ,the car is 11 years old change all heater and radiator hoses.
Mar 30, 2014 | 2003 Mazda MX-5 Miata
My radiator on my 86 mazda keeps loosing water
well, check the hoses first...do you see anything wet around the clamps or ends of either of the hoses? If not then look at the radiator cap...is there fluid around it? Look at the overflow bottle that is near the radiator...is it cracked? Finally look straight down at the radiator from above the cap...do you see fluid on ANY part of the radiator? especially down at the bottom of it? Look around the engine bay, do you see splatter marks from fluid hitting the fan? If you see fluid anywhere on the radiator itself fill the radiator back up and run the truck until it gets hot and see if you can spot the leaks. If however, there aren't any obvious leaks at all up front...go look at the heater lines that run into the firewall...if they have any leaks then you've found your solution. Another place to check would be around the water pump...just get a flashlight and look for fluid near the pulley that goes to the water pump. Good Luck
Nov 07, 2013 | Mazda B-Series Truck Cars & Trucks
How to change a thermometer in a 2003 toyota camry
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
Feb 06, 2012 | 2003 Toyota Camry
My radiator busted on my 1995 Lumina and the man at the wrecking yard sold me one from a 1995 Monte Carlo and now I have transmission fluid pouring out my radiator into my overflow jug, the radiators look...
Thanks.
Feb 04, 2012 | 1995 Chevrolet Lumina
Where is overflow container for radiator?
find the radiator cap, now there is a small hose there, follow that hose to the reservoir. usually near the side of the radiator
Aug 30, 2011 | 1999 Acura TL
Ford Radiator To Fit  Compact Tractor 1700 Logo
337 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
