Question about BMW Z8 Roadster Red 1:18 Diecast Model
I am having problems resolving returns for damaged Exoto Diecasts
I am having problems resolving returns for damaged goods with Exoto diecast cars. Items arrived damaged and when I contacted Exoto to request an exchange, they pretty much have ignored me. Some are obviously prior returns sent back to Exoto with prior damage which they then sent to me. Anyone else have this problem? Recommendations?
  • George Smith Mar 18, 2012
    IF YOU BUY DIRECTLY AT EXOTO.COM AT YOUR OWN RISK AND YOU DONT RECEIVE THE ITEM YOU HAVE ONLY 45 DAYS TO MAKE A CLAIM TO VISA OR MASTERCARD TO GET YOUR MONEY. DO NOT BELIEVE ANY PROMISE FROM EXOTO TO EXTEND MORE TIME FOR STOCK. THEY ARE THIEVES AND TONY KEUSSEYAN IS A BIG SWINDLER AND MAFIA INCREASING THE PRICES AND CREATING HIS OWN BLACK MARKET.
Exoto is a mafia. The only thing that they done well are their diecast. The rest is the worst you can find.
Posted on Dec 13, 2010
NEVER BUY AT EXOTO.COM. THEY ARE THIEVES AND NEVER GET A SOLUTION WHEN YOU HAVE A PROBLEM. THEY SELL ITEMS THAT THEY NOT HAVE IN STOCK.
I NEVER AGAIN I WILL BUY AT EXOTO.COM. THE WORST EXPERIENCE I HAVE. TONY KEUSSEYAN IS A THIEF, A SON OF A B.i, TCH.
Posted on Mar 15, 2012
SOLUTION: NEVER BUY DIRECTLY FROM EXOTO. THEY ARE THIEVES.
Posted on Aug 06, 2011
  • chetu554 Aug 06, 2011
    IF YOU WANT EXOTO DIECAST BUY THEM FROM EBAY. NEVER BUY DIRECTLY FROM EXOTO.COM BECAUSE YOU 99% PROBABLY WILL RECEIVED A DEFECTIVE MODEL AND YOU CANNOT GET YOU MONEY. THEY ARE THIEVES AND FRAUDSTERS. YOU CAN SEARCH IN GOOGLE A LOT OF CLAIMS AND PROBLEMS FROM USERS ABOUT EXOTO.
Why would my 1995 Mercedes e320 air conditioning fan works only sometimes?
Who knows,can not guess for an answer
Maybe the motor is bad
Maybe the control circuit has issues
You really must know that all vehicle issues have
to be resolved with proper testing & you can't even
do that if you don't know how the system & components
work,so you need info before you start.
Jul 17, 2014 | Mercedes-Benz Mercedes E Class E320...
Car starter
Pinion gear solenoid is damaged on the starter/ not disengaging when key returns to RUN position,
OR YOUR STEERING WHEEL KEY SWITCH IS DAMAGED AND THE CONTACTS FOR THE START POSITION ARE DAMAGED AND SHORTING IN THE start position.
OR the starter solenoid in the engine compartment not on the starter. (see botton re:contractors truck)__
and
Could be dry metal and burring ie freezing up stuck
a product called ACS 50 or corrosion block by lear inc. is great for all electrical components. lightly spray in the key hole then gently turn key in all directions to lube it up. this may fix the glitch if it's in the key switch assy.. if not check the starter by disconnecting wires "as you need to to r and r it. but hot wire it by jumping the contacts for the START Mode. if it spins and stops when you unHotwire it when engine running, it looks like KEY SWITCH problem. BEFORE RIPPING INTO STEERING ASSY TAKE THE STARTER OFF AND TAKE IT TO THE PARTS STORE TO TEST IT. Its the lesser of two dismantles. these are events I have experienced dozen years ago and this year on a contractors truck. He had to go under the hood to jump the starter solenoid I ACS'd key asy and it resolved his problem.. so its a start to debug and resolve. can't think of another at this time. good luck. greg
May 06, 2012 | Cars & Trucks
Automatic Transmission will not shift into any gear
A blocked oil pan filter could cause the issue, or the fluid is low. This would be the beast case, otherwise there could be serious damage inside.
Mar 12, 2012 | Ford 1963 Ford Falcon Futura Convt Dark...
Can i replace the 15" woofer with diecast aluminum
Yes. Contact CV for a replacement. Alternately, if you have a speaker refurbisher in your area, you can have them rebuild the one you have. There are only a few refurbishers/rebuilders in the US, so good luck.
Aug 04, 2011 | Cerwin Vega V-152 Main / Stereo Speaker
When we scan or copy, a long line comes up on the paper
You might need to clean the corona wire. Pull out the drum and cartridge and slide the blue tab on top back and forth. Be sure to return the tab to the home position afterward.
Mar 01, 2011 | Brother MFC-8460N All-In-One Printer
Citroen xsara picasso (51 plate). brake lights
Above the brake pedal is a switch that has a little plunger that comes out when the pedal is pressed, the switch is also the stop when the pedal returns, this can burr the plastic and jam the switch (I have seen this twice) or the switch coud just be dead.
Sep 19, 2009 | Bburago Citroen C6 Diecast Model
Bolt from breather fell into carburator
Get a magnetic tipped rod available at most NAPA or car part stores. (it's a common problem) and try and fish it out. Hopefully it hasn't gone down your intake manifold yet. If that doesn't work remove the carb and get it out. It will not safely pass through your intake manifold, through an intake valve, rattle around in your cylinder, out an exhaust port, through your exhaust manifold and out your exhaust pipe without doing major damage. You need to find it and remove it before you start your car again.
Jun 01, 2009 | Mustang 1/18 1969 Ford Boss 302 Diecast...
TIE RODS ARE RUBBING ON RIMS ?????
may have other damage to suspsion components
Apr 24, 2009 | Chevrolet 1972 Blue & White Chevy Pickup...
Long periods with no signal - NUVI 660
Try to take it out of the car so that it has a completely unobstructed view of the sky. See if the signal problem is resolved. If that resolves the problem then you will need to find another place to attach it to the insude of the card. If that doesn't resolve the signal problem you will need to return it to the manufacturer. They have a program where they rebuild it for a flat fee regardless of what is wrong with the device.
Apr 02, 2009 | Garmin Nuvi 660 GPS Receiver
BMW Z8 Roadster Red 1:18 Diecast Model Logo
1,022 people viewed this question
Top BMW Toys Experts
ray gallant
Are you a BMW Toy Expert? Answer questions, earn points and help others
