Question about HP Pavilion dv6000z Notebook
L100 touchpad hi. well i have a toshiba satellite l100 laptop. the touchpad hasnt been working for a while now, and i've tried all the settings. can you help please? a.s.a.p
  • jodherb Feb 18, 2008
    can any1 help plz
  • 21 Answers
Check in the BIOS settings, If you have a mouse plugged in, it may disable the touchpad.
NOT SURE? see a Tech.
Posted on Feb 18, 2008
Toshiba Satellite 1905-S303 keyboard and touchpad mouse will not work
Hi TiKLe
Try to go into the "safe mode" by pressing repeatdly F1,or F2 or F8 (depending on your computer) and reinstall your keyboard/touchpad drivers from the Toshiba website below.
If that does not work, then try downloading the drivers on a thumb/flash drive on a different computer and go into the safe mode on your computer and insert the flash/thumb drive in and download the drivers for your computer that way.
Go to the following webpage and download your drivers.
Please rate me
Bud
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=256525&rpn=PS192U&modelFilter=1905-S303&selCategory=3&selFamily=1073768663
Sep 26, 2012 | Toshiba Satellite 1905-S303 Notebook
I accidentally deleted the installer of my toshiba satellite m35x - s109 touchpad...now the touchpad is no longer working and the 2 buttons below it...please help
hi flyrech,
You can just your touchpad needs a driver for it to work fine again. Here's the link:
http://www.driversforfree.com/omn_ofm_omd/toshiba/satellite/m35x-s109/drivers.aspx
Just download and install the "Toshiba Alps touchpad driver".
Hope this helps, inform me this is solution effective or not. Thanks.
May 12, 2011 | Toshiba Satellite M35X-S109 Notebook
I have Toshiba Satellite L100-179 but it doesnt have audio drivers, whare can i get them
The best place to get these drivers is Toshiba.com or you could go to. driversguid.com or drivershq.com
hope this helps.
Apr 08, 2011 | Toshiba Satellite L100-173 L100-175...
How do you adjust the touchpad on the Satellite L505 Toshiba?
Hi, to adjust the touchpad settings for your Toshiba L505 kindly follow the Step by Step intruction guide on this link,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Mouse+pointer+jumps+around+as+you+type
You will see several search results, just click the topmost result which says "Mouse pointer jumps around as you type". You will then see a detailed guide on how to adjust touchpad settings. Hope this works for you.
Oct 30, 2010 | Toshiba Satellite L505ES5018 Laptop
How do i get touchpad on toshiba laptop to work?
Control panel (classic View). Click the mouse icon. Under TAB TouchPad ON/OFF make sure TouchPad is set to Enable.
Under advanced tab, click Advanced features setting you will find additional configurations for the touchpad.
Hope it helps.
Sep 26, 2009 | Toshiba Satellite M115-S1061 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
Toshiba Satellite touchpad sensitivity
if you go to :
  1. control panel
  2. hardware and sound
  3. mouse
  4. device settings
  5. click the "setings" button
  6. then go to sensitivity
i hope this works as i have a toshiba a200 laptop. while you're there you can toggle palm check in case you lean on the touchpad.
Jul 24, 2008 | Toshiba Satellite A135 Notebook
Synaptics touchpad not working
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
HP Pavilion dv6000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
