Question about HP Office Equipment & Supplies
Ink cart. are leaking, how do i clean heads and ink out from inside printer?
    President:
  • 3,085 Answers
Soapy water only and lots of cotton swabs
Posted on Jan 31, 2010
The head cleaning cannot be completed by the printer?
Epson printers use a lot of ink to do head cleaning. If you're low on ink, it will give you that message. Put in new ink carts, and head cleaning will happen. You may want to purchase "cleaning carts" that have a special solvent to help un-clog the print heads.
Sep 11, 2014 | Epson Office Equipment & Supplies
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
Printing but blanks
did the print out improve after your clean the head?
If all fails, try this last method.. take out all the ink and switch on the printer, when the printer detected no ink, it will ask you to insert the ink cart. Put back the ink cart and let the printer do ink charging.. pls make sure there is ink in the cart else it will damage the head.
After the ink charging, print a nozzle check and see if there is any improvement.
May 25, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc 640cw I changed the black ink and its telling me near empty ink and will not print,
Try this
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Apr 23, 2010 | Office Equipment & Supplies
My cannon MP830 is leaking back ink. Is there
Take out the black cart and have a look at the top surface - you'll probably find that the label has torn back too far. This lets too much air into the top of the cart and consequently the ink is free to run out of the bottom.
You'll most likely have to throw that cart and get a new one. Clean the inside of the printer with kitchen roll, making sure you get as much ink out from the area where the head parks at the side.
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Yellow not printing on test print -
You either have a leaking cart or the print head has become cross contaminated. Remove all the carts and check the feed hole under each of them. Make sure they are the color of the ink in the cart. Remove the print head and, using a damp cotton bud (water ONLY!) give the print head a clean. DO NOT use the same cotton bud for all sponges.
If that doesn't solve it then take the print head to a re-inking firm and have it cleaned professionally. Won't cost much and will hopefully solve the problem.
Sep 14, 2009 | Canon Pixma iP4500 InkJet Printer
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
HP officejet 6210.
Put the printer in the mode for changing the carts. Take out the Black ink car and clean off the heads on it. Looks like brown in color it's on the cart at the bottom To clean use paper towel with cold water never use warm or hot. Clean the area where the in rest in the printer also if you can reach it. The noise you hear is that the cart didn't go back in the right position. You have to be cart not to force these carts out as everything in this printer is made of plastic.
Jul 23, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Ink Leaks
Richard,
I dont understand "inverting". Do you mean turning the machine around (180 degree) to see the bottom of the machine?
Anyway, inkjets used to stain after a while. This is because of serveral reasons: the ink absorber felt is getting wet due to the cleaning cycles, some ink will splash from the printhead, ink will flow back from ph to cart etc.
Do you refilled the original carts or do you use generic carts? The latter one do NOT keep the ink inside the cart when turing the machine to bottom (e.g. for Postal sending) due to diffrent construction.
You should use original carts for refill. Make sure the plastic support secures the carts.
Only original carts wont leak!
Mar 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Printing problems
It could be that the underside of your head has a clump of ink on it and this is dragging across the paper. Contact http://www.TheServiceManualShop.com for there document about head cleaning - the document is not listed on the site but they can email it you. If this is not the issue then it could be that a cart has leaked into the cart carriage and is colouring one of the other inks. This is not that likely however as blue is a primary colour and can't be made by mixing inks. If it was for instance green bands that it would be plausible that blue ink was leaking into the yellow or vice versa. Another option is that the piezo thing that actuates the ink being fired is capput and allowing blue to leak through to the nozzles all the time. Or that the print head or main board is faulty. I'd try the cleaning first - it's the easiest option.
May 06, 2007 | Epson Stylus Photo 1290 InkJet Printer
24 people viewed this question
Seeker5211
Seeker5211
