Question about Toshiba Satellite M55-S325 Notebook
Screen Fades out/distorted
My screen will fade out and get distorted...if i press it and hold down it will be clear...when i let go its destorted again....can this be fixed? or will it be better to get another laptop?
  • Matt147 Apr 02, 2008
    I have a Satellite M55-S1001 and have the same problem with the screen. The screen can fade to grey, the colors get inverted, and at its worst all I see are vertical streaks of color. If I tweak (slightly bend) the screen and apply pressure to the top of it, the picture returns to normal (as long as I maintain the pressure). I checked to make sure the video cable was not loose and it was connected just fine.
    Scholar:
  • 181 Answers
If you're pressing on the lcd itself, it could mean the cable is coming loose, in which case is easily repaired.
If you're pressing somewhere else on the laptop, it could mean many things. Either way, I'd certainly check around for a reputable locally owned repair shop specializing in laptop repair (such as ours does ;~) To bad you aren't in Broken Arrow Ok. or I'd be glad to take a look.
Good luck
Posted on Feb 19, 2008
Sanyo DP46848 screen fades to white. Sometimes it comes on okay, then fades. Sometimes starts white, turns on normal then fades out. Ideas?
many components can work when cool but after heating up lose conductivity, could be many different components that might cause this, needs a professional to track it down
Dec 24, 2015 | Sanyo Televison & Video
HOW TO FIX JVC LT47X788 PIC FADES OUT
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | JVC Silver Tilt/Tilting Wall Mount Bracket...
Laptop screen fades in and out
try to move your lcd screen in forward and backward direction, see where you gain the display. if this didn't work, try to press the side around the lcd and see where gain the display.
by then you tell whether you have the loose connection or nearly bad lcd.
thanks
Mar 30, 2014 | Lenovo ThinkPad T61 Notebook
17" flat screen not displaying
This message "safe mode press any key" sounds more like the problem is in the PC. You need to try another monitor with this PC, also try the monitor with other PC. Need to narrow down the problem first. Plase post back.
Apr 08, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
My psp's screen somtimes fades out to black or
you damaged the screen i suggest seeking a repairman or send it in for repair
Oct 27, 2009 | Sony PlayStation Portable (PSP) Console
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Canon DC100 LCD screen fades out
you might need a new lcd you could open and check the flex theres four screws holding it on when you get them off you pry by the bottom with your nail and gently pry it apart it will seem like it doesnt want to come off because there are four claws holding it together just try one side and if that side doesnt budge then go to the other side and try and then you will see the flex use a pair of tweezers to pop up the black piece holding the flex on be careful when you do this step take the flex out and put it back in with the tweezers and gently push the black piece back on sometimes thats all it needs theres also another flex at the other end theres a service note about that flex rubbing against a piece of metal thats holding the circuit board on and causing the lcd to short inspect the flex and if its ok you need to put a piece of tape over the flex to prevent this hope this helps
Oct 02, 2007 | Canon DC100 DVD Camcorder
Computers & Internet Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
