Question about Fantom Vacums Lighting Canister Vacuum
Powerhead for a fantom lightning
I have broken the power head connection at the botom where the hose conects to the power head can any one help/ Before my wife finds out.
  • cauleywbc Feb 18, 2008
    Thanks for the dismal outlook which sure does make my plight even more of a dilemma.
  • Anonymous Feb 24, 2008
    I had the same problem recently. I got a tube of construction adhesive and glued it back together. I then reinforced with a couple of metal mending braces and 3/8 screws I had lying around. I finished off with some cable ties and duct tape for effect. Its been about a month and its still running. Good luck!
  • 78 Answers
I have a good used powerhead and other replacement parts, but I think I read this a little late!
Posted on Mar 21, 2010
  • 126 Answers
You're not going to like this. That company went bankrupt and parts are no longer available. You might be able to find a good used part, but it's been quite a while since the company closed and most parts have been used up. That connector was a problem and was prone to breaking. I think it may be time for a new vacuum. Sorry.
Posted on Feb 18, 2008
Need a new power head
your best bet would be to try Ebay or something like that. These units were discontinued late 1999/early 2000 and no parts are available for it.
my best suggestion in this case is to invest what you would spend on the powerhead into a newer cannister. Some of the newer units have better filtration and suction than the lightning cannister does.
Nov 06, 2010 | Fantom Vacums Lighting Canister Vacuum
Vacuum head stopped working, unresponsive to on/off switch and light bulb is out. Canister otherwise works fine. Help!>?
Power head on/off switch could be faulty, Wires running through hose may be broken, electrical connections may be burnt.Motor in Powerhead could be dead.
Nov 17, 2009 | Vacuums
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Aug 09, 2009 | Fantom Vacums Lighting Canister Vacuum
Powerhead for Phantom Lightning - I need one too!
u'll definity get a new one for it, no worries just call the customer care, they will provide u with the new one, cost some 2-5$ .. thank u
Jul 17, 2009 | Fantom Vacums Lighting Canister Vacuum
Need new power head where can i find one
Select "support wizard", left column.  It should take you where you need to go:
http://www.fantom.com/fantom/GoodBetterBest.aspx?cat=CanisterVacuums(Fantom)
Jul 16, 2009 | Fantom Vacums Lighting Canister Vacuum
Need new powerhead for Fantom Lightning Style PH1A - Where can I buy it and how much?
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested.
Jul 15, 2009 | Fantom Vacums Lighting Canister Vacuum
Fantom Vacuum powder head Parts
In Canada I don't know. Parts for the older Fathoms are getting scarce. There is a wholesaler here in the US that has parts, but you have to be a repair shop to buy from them and I don't know if they are in Canada. Call your local repair shops to see if they can get you that circuit board, the co. name here is Essco, or Electric Sweeper Service Co. Wish I could help more.
Apr 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Fantom Canister
It sounds like you have a hose problem. You should be aware that the Fantom company went bankrupt many years ago. I know that the Fantom name was bought by another company and there may be Chinese units sold under that name, but service and parts availability is an issue. There may be an issue with the power delivery to the powerhead. This is through the hose, from the canister connection and down the wand assy. You should check the continuity from the canister down to the powerhead.
Dec 12, 2007 | Fantom Vacums Lighting Canister Vacuum
Fantom Vacums Lighting Canister Vacuum Logo
1,001 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
