Question about Intel Motherboard
What does it mean when it saids bio's checksum bad
  • 67 Answers
The bios chip has lost it's settings (time, date, hard drive parameters, etc).
The usual cause is the onboard battery has given up and needs to be replaced which is an easy job.
It's possible that you may have a virus (used to be a more common problem a few years ago), or the motherboard itself is faulty.
Please rate this solution if it was at all helpful.
Thankyou
Posted on Jan 31, 2010
HP dc 7600 red light 9 beeps
Hyjacker, Ransford decker ask 6 years later.
ahhh , old BEEPs codes so old that HP even forgets them
over 10 years old./ yours is now 13 years old
first off is the Motherboard RTC coin cell dead, as all are this old?
replace it first. a wise choice. that.
on some HP code 8 is coin cell dead. did you count flashes wrong? the count matters. big time....
on AMI BIOS code 8 means
Display memory error (system video adapter)
later AMI BIOS code 8 means.
ROM Checksum Error
ROM checksum value does not match the value encoded in BIOS.
this means COIN cell bad again.
i see no code 9,s in my huge private lists of bios codes for 20 years.
ok , reading all manuals, on this one PC i find this.
"System not fetching code"
now there is classic geek code, wow.
my guess it means CMOS ram is corrputed.
again the coin cell is bad. table.(fixha wrecked it, sux, no?)
Mar 02, 2012 | HP Compaq dc5100 PC Desktop
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Coooo221 Bad image checksum
Bad checksum means the file is corrupt or your BIOS is out of date.
You can be sure it is the BIOS if it is happening on different files.
please let me know the machine make and model and I can help you check the BIOS?
Dec 18, 2010 | Dell Inspiron 6000 Notebook
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
Bad bios flash, backup gives bad checksum error. downloaded correct ver - still bad checksum. what should I do? AMI bios ver 1.0
Is the mother board working? If so, why are you flashing the bios? If the bios is bad and can not be flashed, you may be able to buy a pre-flashed chip if it uses a removable flash chip. Try this site but you can find others on the Internet.
Mar 24, 2010 | Intel Motherboard
STOP: c0000221 {bad image checksum}
You most likely have bad RAM. If you have two chips, pull one out and run the laptop on a single stick. You may need to alternate the sticks just incase the non-working one is the one you left in the laptop.
May 19, 2009 | Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
Checksum error in bios
the on-board battery may be bad-try replacing it.
Jan 12, 2009 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
