Question about Whirlpool Ovens
I have a whirlpool AKZ163/IX. the oven and clock display has F 10 on it. I cant put the oven on or get it back to the time
SOURCE: whirlpool super capacity 465 / gas oven won't light
Hi.I'm back, no the broiler doesn't glow either. ran some tests and i have 116.4 volts @ the igniter. and when I checked igniter I recieved an open circuit. Tested a new igniter and it showed a reading thus making me believe that the old igniter has open circuit. Also did ohms resistance test ?? on valve regulator and recieved reading, thus eliminating that the valve is probably not defective. So where I'm at is I am going to install the new igniter and see if it fires up . Then do the same tests on the broiler and see where I stand. Maybe our broiler has been out awhile and went unoticed. Till the bake went out. Make any sense? I may sound confused but confident that I will prevail... LOL thanks for everything,
Posted on Jan 18, 2008
  • 18 Answers
SOURCE: Whirlpool single electric oven - model unknown
Turn the breaker off that supplies the power to the oven for 5 minutes to allow the computer to reset. If this doesn't work you my have a bad board.
Posted on Aug 04, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
  • 18 Answers
SOURCE: Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
Posted on May 17, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
I have a whirlpool built in oven AKP 239/IX/02 When I try to turn the oven on (both dials) the sign "- - - C" discpays on the digital display screen and the oven will not turn on.
We're sorry to learn of your experience. For further assistance with your Oven, we recommend the link below. You may contact our counterparts in your Region due to you are outside the US.
http://www.whirlpool.co.uk/
Jan 17, 2018 | Whirlpool Ovens
Whirlpool Absolute Built-In Oven in Stainless Steel AKP 7460 IX user manual ?
Dalene, we recommend the link below for the User Manual.
http://www.whirlpool.co.uk/appliances-1/ovens-3/whirlpool-absolute-built-in-oven-in-stainless-steel-akp-7460-ix/857774601700/
Jan 16, 2018 | Whirlpool Ovens
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
Having trouble with the clock display
try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Jan 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
121 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
