Question about Hotpoint Dryers
I have replaced the belt on my Hotpoint vdt00 dryer but the belt seems to pull the drum on to the motor causing a scraping noise and its hard to turn around. their dosnt apear to be a bearing or anything to hold the back of the drum up off the motor. shaun
  • Hotpoint Master
  • 2,696 Answers
Look inside the drum is there three screws on the very back wall of drum,there is a bearing there,remove the belt,slide the drum forward and look at the back of the drum,there should be a shaft sticking out that slides into a slot that looks like a U in the back wall,that is the rear bearing that you get in a kit if you hear a loud squeaking sound that's the problem,if you sent the model number i could of told you the part number
Posted on Jan 31, 2010
Why does my dryer hum?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Apr 23, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 05, 2014 | Dryers
Maytag Neptune super stack dryer is squeaking. Do
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 04, 2014 | Dryers
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Dryer is scraping as it turns. Is there a belt that is worn? Started doing it after 3rd load. Did the same last time we used it.
The dryer drum is suspended between the front panel and the back panel by extrusions that protrude into the front and rear of the drum. There are thick felt pads attached to the protrusions that support the drum and isolate the metal of the drum from the metal of the front and rear panel protrusions, allowing the drum to rotate freely. A large belt encircles the drum and a pulley attached to a motor mounted under the drum. A spring "thing" applies tension to the belt to prevent the belt from slipping. If the noise is a metal on metal sound, check the condition of the felts. Other causes of noise have been stretched belt slipping on drum, weak spring "thing" not keeping belt tight, motor bearings dry (oil) or worn (replace motor), and pulley on spring "thing needs lube (lube). Hope this helps.
Jan 12, 2010 | Maytag Dryers
I have a Hotpoint Dryer and the belt snapped, we purchased a replacement belt but are having a hard time figuring out how to install the new belt. The instructions call this belt a drive shaft. Please...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 15, 2009 | Hotpoint Dryers
Hotpoint DLB 1550 clothes dryer belt replacement
I don't know of any sites with pictures but, remember just average people assemble these so it's not as hard as it seems. The electrical connectors are one way fit so you don't have to worry about mixing them up. If your worried though use tape to lable where they go. The drum rides on the front of the dryer so when you remove the front the drum will drop down. Remove the old belt and then slide the new belt back to where the old belt rode on the drum. Make sure there are no twists in the belt. Loop the belt on the motor pulley and the loop it over the tensioning wheel. Make sure the tension wheel puts plenty of tension on the belt. Have someone help you hold the drum in place while you put the front on.Before you close the top turn the drum by hand to make sure it turns smoothly. Then close it up and run it empty and listen for squeaks and scraping sounds. Good luck and if you have more questions ask. I can help you through if you need help. Please rate me so I know if I'm helping. Thanks
Dec 30, 2008 | Hotpoint TDL15 Electric Dryer
Dryers Logo
178 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
