Question about Toshiba Computers & Internet
Port says cables not plugged in but the cable is and is a working cable i have windows 7 installed need to know how to fix this so i can connect to internet
Same problem. I think we're all stuck with it, at least for now. Intel is of no assistance after many contacts, and the tech from Dell said they simply don't have the correct driver for our adapter (which is the problem), not to this date anyway according to him.
The diagnose and repair feature on Windows 7 will fix it until the next nap time. Just leave it on until you're absolutely finished in the evening, or whenever. I think that's all we can do
Posted on Jan 31, 2010
Camera not connecting to computer
If the cable is working fine then check the port on both camera and PC. on the camera maybe there's some dirt or lint stuck on the port try to clean it. On the PC might wanna try other ports usually the one at the back is recommended.
Jun 06, 2017 | Nikon D300 Digital Camera with 18-200mm...
I have just purchased a Belkin N600 modem router. I have attached my Canon i850 printer to the USB port on the router but I cannot print. The green USB LED is not illuminated. Can you help, please? ...
I think you need to connect your printer to the router using an ethernet cable and not a USB cable. Ethernet cables are plug-and-play cables and doesn't require you to install a software. If you really need to connect your printer using a USB cable, you need to connect it to your PC so that the PC will run the installation wizard to install the USB cable. Of course the router cannot run installation wizard to the printer or the printer cannot run installation wizard to the router.
Sep 11, 2011 | Belkin Play N600 Wireless Dual Band Router...
I want to install hp deskjet 3325 in windows 7 ultimate, I have driver CD which works on win xp, how to install the driver for hp printer on win 7?
Follow these steps to install the compatible driver in Windows 7.
  • Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  • From the Windows taskbar, click the Windows icon ( ), and then click Devices and Printers . The Devices and Printers window opens.
  • Click Add a printer . The Add Printer window opens.
  • Click Add a local printer .
  • Click Use an existing port .
  • Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  • Under Manufacturer in the Install the printer driver window, click HP .
  • Under Printers , select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next .
  • In the Printer name text box, type the product name and then click Next . The print driver starts the installation process.
  • NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.
  • When the installation is complete, a message displays on the computer stating that the product was added successfully.
  • In the message window, click Finished .
  • Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  • Click Close (X ) to close the window.
Nov 04, 2010 | Computers & Internet
I need to connect my hp 1115 printer to my windows 7 computer and I don't have disc to install it. Please help!
We can use generic drive of deskjet 550c to install this printer. Just follow the below simple steps to fix the problem.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers,select HP deskjet 550c and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Thanks and Regards,
Rizwan
Feb 01, 2010 | HP PhotoSmart 1115 InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
Will not work with usb cable
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install - (1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark Office Equipment & Supplies
'Communication Not Available' message when printer cable connect
To fix a fouled install:
(7) When the software asks for the printer connect it and continue
Nov 18, 2008 | Lexmark X2250 All-In-One InkJet Printer
Usb problem
You shouldn't need the USB driver 2.0 from mercury because windows installs this with SP2. Suggest you un-install what you installed from mercury & update your version of windows (completley), through "Windows Update". Once windows is all updated & you have finished with a reboot. Plug your pen drive in a opened usb port. Open windows explorer. Scroll down & you should see an icon (left side of explorer), thats named like, Removable Disk. Give windows time to see the device. After a few minutes if your pen device does not show up try another usb port. One you know does work. If after a couple of minutes go by & you still don't see the device listed in explorer I would say the device is defective. Your Mp4 uses a cable to connect to the usb. Try connecting to another PC's usb port. It is possible the cable is dirty or bad.
Jan 13, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
