Question about Tascam FE-8 8-Channel Expander for FW1884 Sound Card
Tascam FE-8 my FE-8 no longer shows an LED light to show power or firewire connection, And when you turn power on fader 6 and 8 shoot straight up automatically to flat out, so basically it feels like it has powere and signal nut wont work, can u help me? please
  • tcaster Sep 27, 2008
    I have two FE-8's that are down after a firmware update to them . When i power them on all lights come on then go off and apears to remain off with no firewire or power light lit but you can tell they have power because you can feel resistence in the fader movements .
    They no longer show up in the FW-1884 control panel
    I have tried everything .
  • JM tascam Mar 21, 2009
    my FE8, after a firmware upgrade (the latest available on the TASCAM website), while "on", but LED indicating power and  led firewire... erase forever.
    The tascam window not recognizes the FE8
    I need help
4 Suggested Answers
fire sine
  • 382 Answers
SOURCE: tascam 2488
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Posted on Nov 10, 2007
  • 189 Answers
SOURCE: Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Posted on Jan 05, 2008
o2bucfree
  • 7 Answers
SOURCE: dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Posted on Jan 08, 2014
I show signal on inputs 5&6 but no sound
I think it has a bug and you need help you can call for an expert
Aug 05, 2014 | Tascam FW-1884 Firewire Audio / Midi...
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
All the lights in my tascam 1884 are on with the firewire and stop buttons flashing.. What is the problem
hola tengo el mismo problema las luces no se apagan si encuentras la solucion ayudame por favor acustic_vision@hotmail.com
hello may you help me my tascam is with light turn on every time help me please
May 19, 2010 | Tascam FW-1884 Firewire Audio / Midi...
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
Tascam 2488
In the monitor section on the 2488 console (upper right) make sure your monitoring source is set to 'stereo'. Then make sure your 'monitor level' control is turned up. The 'stereo' fader (sub mix fader on the MKI, stereo fader on the MKII).
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam FE-8 8-Channel Expander for FW1884 Sound Card Logo
82 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
