Works fine remote wont scroll across led lights up when scolling across it moves up or down on screen
  • 2,335 Answers
What is the make and model number of your projection tv?
The more information you provide for us to start with, the more accurate our solutions can be for you.
Posted on Feb 02, 2010
Need the code for rca DVD RTD315 SYSTEM FOR DirecTV REMOTE RC66X
Direct TV press menu scroll down to settings& help select settings scroll down to remote control select program remote AV2 select select DVD scroll down to RCA move switch to av2 codes press mute and select until light flashes twice enter code press powerare 20522,20571 ect more codes are abailbe by selecting more codes if code work move switch back TV
Jul 24, 2015 | RCA Televison & Video
Sanyo PLC-XL51 won't turn on with remote. I have been told that you need to hold down two buttons on the remote for several seconds - but which 2 ?
If you go here http://www.projectorcentral.com/pdf/projector_manual_4557.pdf and scroll down to page 3 click on troubleshooting page number I think 65 then scoll to page 66 and remote not working is listed first on that page I beleive your problem will then direct you to page 51 and the button combination you are asking about is listed there and an illistration is even shown.
Jun 02, 2011 | Computers & Internet
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Did not come with instruction booklet...help!
You have not stated which type of remote control you have but most remote functions are self-explanitory by the details on the keypad. Mostly if you use the menu button & then scroll up/down to access which function you wish, then scoll to the right to access the sub-menus.
Oct 21, 2009 | Televison & Video
Wont turn on
lg has a problem with that model--usually bad electrolytic caps(most of the time the tops of the bad caps are swollen)if you take apart the unit you should see them problable in the power supply--if you dont think you can change them--contact a local shop-ask 4 price 2 change them or u can go to shopjimmy.com--enter model number--scroll down til u find power supply--if not in stock write down part number--google part number to find one
Sep 18, 2009 | LG 32LC2D Television
The light flashing led yellow and wont turn on, when it decides to flash a green light if we can catch it and push the remote on button numerous times it may come on..the screen flashes a bit and goes...
philips has a problem with bad(swollen)caps in the power supply you can replace the caps yourself or go to shopjimmys.com enter model number scroll down-find power supply-if they do not have it in stock write down part number google to find some one that does
Sep 11, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
My 880 only works from about 3 feet away but used to work fine from across the room. The battery is new and charged and I have updated the firmware and the settings. It works fine up close but not at...
you need to return it. one of the IR led only works. I had that, had to return (RMA) the unit. you can check with some camcorders to see how bright the LED is (the camcorders often can 'see' the IR led like a white light).
i.e. either the power circuit for the IR LEDs is failing or the IR LED themselves are dead.
there is nothign you can fix on your own. CAll the support and get a replacement unit. or return the remote to a store if you just bought it.
Feb 24, 2009 | Logitech Harmony 880 LCD Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
