Question about Sport & Outdoor - Others
I work in a fitness centre and we have schwynn bikes in our spinning studio. Customers keep complaining that some of the bikes are slipping?? Schwynn have assured us it is their technique and they are experiencing the safety mechanism not the bikes slipping? Please could you explain as I do not understand?? It would be great to have instructions if it is our customers technique for a correct smooth cycle on these bikes. Some of our customers have actually changed bikes and been fine?? Please help!!
    Problem Solver:
  • 18 Answers
Schwinn may be right in that the spin bikes have a "clutch" on the flywheel that would keep it from causing to much damage to your leg if you slipped off the pedals. Also as the bikes get used these can become worn and require rebuilding, so some bikes wear faster than others so one may seem fine and another slips. Get on the bike pedal forwards and try to stop then you can feel it and see which slip more.
Posted on Feb 13, 2010
What would make the serpentine belt keep slipping off
Failed Water Pump
Crankshaft Damper Worn
Failed Belt Tensioner
Failed bearings in any accy
Aug 16, 2014 | Cars & Trucks
Gears keep slipping
Have a trusted bike shop adjust the shifter cables. I'm told that all new bikes need to be re-tuned a month or 2 after purchase due to cable stretch.
Jul 30, 2012 | K2 Easy Street Men's Cruiser Bike
Rear axle replace
screw 1 of the cone pieces(that fit bearings)tapered section towards centre of axle(about 3/4 inch), then slip 1 bearing case on axle from other end with bearing side facing centre. Then insert axle into hub and put bearing on other end(bearings facing middle)then cone.
**NOTE** Put small amount of bearing grease inside hub for bearings. Doesn't have to be bicycle grease- I use auto grease as you get 10times as much for same price.
Then adjust cones by hand untill there isn't any slack and axle centered.Then screw on thin nut(both ends), it acts as lock nut for cones.To tighten correctly you need a skinny spanner to hold cone while you tighten the skinny nut. Spanners from bike shop only cost about $2. Can adjust without a narrow head spanner by leaving a bit of slack when doing up cones and hopefully lock effect between cone/nut grabs before cones are over tight(a bit of messing around without a narrow spanner).
There shouldn't be any slack between axle/cones and wheel, wheel should spin freely.
Put wheel on bike then a washer(if you have any)outside frame, then larger wheel nuts.
Hopefully all your pieces have been used. HAPPY RIDING
Jan 13, 2012 | Schwinn 26" Mens Cruiser Bicycle
How to fit drive belt
really simple, take off the top, put the belt round the little cog first then, start putting it on the big one, whilst turning the turntable! try that
Feb 06, 2011 | Aiwa PX-E860 Turntable
I AM WANTING TO INSTALL DIGI GEAR INDICATOR in need of advice
hi as datatool offer limited information on your bikes wireing , you will have to find your self a wireing diagram for your bike and work out which colour on the machine goes to , speedo , tacho, live, earth, neutrol, the hard part will be teaching the gears as you have to run the machine on a stand in each gear to program the unit, which will be difficult to stabalise the bike, who did you buy the unit from can they not fit it for you, datatool websit gives you a list of aproved fitting centres in you area,
Dec 10, 2010 | 2006 Honda VTX 1300 S
Servicing charge
Sorry to hear of your troubles, but you 've somehow posted them on a do-it your self wbsite, from the intent of this letter i would assume that you would have liked to post it somewhere else.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Immobiliser for the mx 125
if none Ins companies that do a single policy for 4 bikes in the UK . However Aprilia don’t fit a immobiliser well not on my 04 bike .Which means an extra £50 on my policy. So do you lot have one fitted are they worth it ? or pain in the bum. They are offering to current customers a Thatcham approved one for £179 with three year warranty fitted at home. In theory it should pay for its self in 4 years so sounds like a good move. Any thoughts ? ,I've a Meta 357T-V2 alarm / immobiliser fitted. Is it worth it? I doubt it, but I went with it, at least I can hear it if it goes off in the garage! At £299 fitted I'd have to keep the mx a while to pay for it. Does anyone here in the UK take any notice of an alarm going off? and what's the point of an immobiliser on a bike? Wheel it away to a waiting van and strip it down later.,,,
Nov 10, 2008 | 2008 Aprilia Pegaso 650
Dualit Combi model (made in UK)
service center in US:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700 ask for Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Oct 28, 2008 | Dualit Vario 3 Slices Toaster
Sport & Outdoor - Others Logo
83 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
