Where would i get parts for a celestial air con
The fan has lost blades and it vibrates like mad cheers jed
  • 22 Answers
Get a new fan blade, to replace the entire fan, it is out of balance and will eventualyy kill you motor and cost more to repair....Turn IT Off
Posted on Feb 01, 2010
How to eliminate vibration sound when air con is turned on on my 1997 jeep grand cherokee 4 lt
It sounds as if you either have some debris in your blower fan or have some broken fan blades. You need to remove the blower motor and inspect the fan, clean any debris that is in the blower housing and replace any broken or worn parts.
Dec 14, 2014 | Jeep Cars & Trucks
Severe vibration during operation of dometic b3300 air con
If this started after the new fan was installed,then the housing the fan sits in is not secure.Or the fan blade is out of balance which means you will need a new fan blade.
Check that all nuts and bolts are tight.If there is a belt be sure it is not worn or missing pieces.
Nov 03, 2011 | Heating & Cooling
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
The fan on my 13,500 BTU air conditioner started vibrating excessively yesterday when I started it. It doesn't matter what speed the fan is on it still vibrates. It has been approximately 2 months since...
Check fan blades carefully for bent blades and also check
the back of the blades.
If any blades are broken you may have to replace it.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 05, 2010 | Dometic Rooftop RV Air Conditioner
Hi my bmw 523 model 1997 the air con fan is not
clogged fan with debris. bad resistor or 3. remove fan, run 12v directly to it to see if it spins. plenty of threads w/pics on how to do this.
Jul 17, 2010 | BMW 525 Cars & Trucks
I have a carrier window unit that lost a fan blade
you can by a fan blade. any refgriation parts store can get you one or you can get the model number and order one off the internet.
Jun 30, 2010 | Carrier BCA101R Air Conditioner
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone Allure® I WS136BC Kitchen...
Heating & Cooling Logo
373 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
