Question about LG Art Cool LA091HNP Split System Air Conditioner
Heating does not start appears a light circle with am asterisk and small drop inside the circle ()art cool lg
  • 22 Answers
Possibly a freon charge issur, or thermistor problem, in the heat mode the indoor coil has to be a certain temp. for the fan to run, if it does not reach the temp because of a low charge or a sensor that is defective, could be more complicated but usally not. Note: if it is low on charge you have a freon leak that needs to be repaired.
Posted on Feb 01, 2010
Does not produce Heat
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Nov 14, 2014 | LG LA120HYV Art Cool 120HYV Ultra...
Cooling light flashes 4 times. Unit appears to shut down.
Your documentation or electrical cover may refer to 4 flashes. What does it say?
Oct 25, 2013 | LG LSN091HSV / LSU091HSV 9,000 BTU 20 SEER...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
LG MC07AHR and MA09AH1 do not heat!
What you have is two fans, one for the outdoors and one for the indoors.You indoor fan is not running and it is not a good idea to run your unit. There are several reasons for this fan not to be running, but the most common is that it is bad. AC mechanic or good electrician can check this out.
Nov 05, 2008 | LG Art Cool LA121CNP wall/window Air...
Lg ductless no ac
I may not be of much help but I may be able to guide you into some diagnosos. If there is a communication problem between the inside and outside unit, both on the inside and outside units a colored LED will bling 5 times then pause for 3 seconds. The 33 and 44 codes are confusing to me because I have never seen this. Try resetting the outside unit with no call for heat or cool from the inside unit. After about 20 seconds, restore power to the outside unit. Go in and turn on the remote and make sure you lower the cool setting more than degrees cooler than the room temp. After 3 minutes the outside unit should turn on. If you get an error code of either 1, 2 or 5 blinks document it for the technician. If you continue to get your 33 and 44, you have a bad control board. If all else fails, press and hold the button located on the lower left side of the art unit and hold for about 5 seconds. If it still no longer works, now you will need the help of someone who knows these units.
Sep 08, 2007 | LG Art Cool LA121CNP wall/window Air...
LG Art Cool LA091HNP Split System Air Conditioner Logo
175 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
