Question about Casio EXILIM Card EX-S770 Digital Camera
Video recording when i go to shoot a video it only captures up to four seconds of footage WHYYYY lol
It only does that because you need a biffer memory card.
Posted on Feb 20, 2008
Hi, I am having great difficulty capturing video, frames are dropping continually plus there is no footage display on the monitor window. Footage allready within the program plays back OK. Any help that...
Hello bazmaz
You need a very powerfull computer to capture and edit video , at least a Pentium 4 at 3GHz , 2 GB RAM . You will still probably loose frames in High Quality mode , meaning a recent Intel 7 series will give the best results .
I have myself experienced that the best results are obtained with a stand alone DVD recorder , preferably with a HD included . This is really the best way .
Regards,
fanaudi
Mar 05, 2011 | VideoLabs (A02105) Video Capture
How to edit picture?
I you refer to video;
First thing is to establish what type of footage the camera shoots.
Then capture the footage to a computer with an editing application that is compatible with the footage.
Without specific information it's only a guesswork.
Feb 05, 2011 | Video Cameras
Showbiz DVD 2: Can see the footage live but can't capture it
Try using another one, like hypercam 2. Or Camstudios. They probably works.
Aug 06, 2009 | Computers & Internet
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Sony HDR-HC3 camera won't connect in HD mode in iMovie HD or FCP HD
What software are you using to capture the HD footage? Are you using the supplied software, or another package. It is likely that you have a software incompatibility. i.e. windows will recognise DV natively, but HDV requires specific codecs and software installed on your PC.
Aug 30, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Sep 15, 2005 | Panasonic NV-GS50 Mini DV Digital...
Casio EXILIM  Card EX-S770 Digital Camera Logo
24 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
