Question about Vacuums
Karcher A 2534 pt Instruction manual . I need a full English manual for the above that explains the working of the unit in easier language. How does the water get to the carpet and back to the well in the cleaner?
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Posted on Sep 20, 2008
  • 14 Answers
SOURCE: Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Posted on Mar 06, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
heatman101
  • 43501 Answers
SOURCE: Instruction manual for a bissel proheat model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
Where's the serial number on the karcher WV window vacuum
Hi. I've just bought the karcher window vac wv50 & am having the same problem finding the serial No. I presume you want to register your product for the guarantee to be valid. I went online Karcher.co.uk & registered mine. You will note that when doing so it does not ask for a serial number but a model No. This is found on the side of box you got the item in (mine is just above the barcode) & it reads something like; 1.633-113.0. Hope you still have the box!
Jul 23, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
Our operating manual is in Swedish and we have lost it. Can someone explain how the answerphone works?
What make and model answering machine do you have?
Are you looking for one written in the Swedish language or in English?
Please reply back. Thanks,
Handie Andie
Apr 21, 2011 | Vacuums
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
I need instruction manual for E+r sewing machine
Hi
What is the model number?
Some E&R manuals are available free to download on the Aisin French site.
This one is in English, it may be useful if it is similar to your machine.
http://www.aisin.fr/catalog/download//RS2000%20manual%20SD%202D%203D%20EN%20FR%20NL%20IT.pdf
If not, have a look here
http://www.aisin.fr/index3.php?language=en
Some of the manuals are multi-lingual but a few are only available in French.
They have manuals for E&R Classic Models CB24, NT21, KPN5000, SC40, SC12 and SC12C.
Hope this helps!
Oct 25, 2010 | Vacuums
I need to find an instruction manual for the Regal Kitchen Pro breadmaker model #6782
You can pick the manual up at E-bay at this URL:
http://cgi.ebay.com/Regal-Bread-Maker-Machine-Instructions-Manual-Recipes-/260662519242?pt=Small_Kitchen_Appliances_US#ht_1196wt_1055
Tried to find it for free but could not. Paul
Oct 04, 2010 | Vacuums
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Scumbuster S600
According to B&D, the nicad battery can be replaced & disposed of at a DeWalt Factory Service Center; call ahead for battery availability. Also, for DIY folks, peruse the instruction manual at http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90500564.pdf
Aug 08, 2007 | Black & Decker S500 ScumBuster Handheld...
Vacuums Logo
195 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
