Question about Hotpoint Dryers
Door handle on hotpoint vtd00p broken.
Door handle on hotpoint vtd00p tumble dryer broken. How do I open door?
  • Anonymous Mar 22, 2014
    The handle has broken how do I open the dorr?
  • Hotpoint Master
  • 3,463 Answers
Remove top cover and force door open from inside with along handled srewdriver or similar.
You may damage door lock in process, but you do not have any other options.
Posted on Jan 31, 2010
Testimonial: "Advice confirmed top could be got off. Once this done it is possible to strip off a side panel and access the lock by hand. Door open without damage."
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
CTD85 tumble dryer: power is getting through to the machine but absolutely nothing happens
Hi.
If there is power then the door switch is probably broken. first make sure that there is power to the machine. The door switch is tested with power off, accessing switch contacts and reading Ohms with a multimeter. When door is closed the switch must have continuity, reading zero or few Ohms. With door open the switch contacts read infinity (circuit open).
If the door switch is OK, test power cord, main switch, wiring harness, motor and timer.
Here diagrams. Click on the pictures to enlarge:
This is a link to all the spare parts available for your Hotpoint ctd85a tumble dryer.
See also : Tumble dryer Video tutorial help.
Sep 18, 2011 | Hotpoint Dryers
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Broken door handle.
Remove top cover, and reach down with a long screwdriver or similar, and actuate the door lever from inside by pushing the catch over.
Please rate my solution.
Thanks.
Apr 11, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
289 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
