Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
  • Hotpoint Master
  • 3,463 Answers
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
Hotpoint Aquarius 321 stuck on spin with all lights flashing
you have a faulty control board unplug the machine take of the rear cover ????
before you take any wires of ''''''''take pictures
then take of the wires
look at the control unit see if you can see any damage
Jan 12, 2014 | Hotpoint Washing Machines
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
266 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
