I need HELP!! i messed up my new iVO-Sound m260 Video MP3 (8GB)..
I've finished installing the MP3 utility tool Setup & was reading and following the User's Manuel Guide instructions... i'm not really that familiar with ''firmware upgrade'' so i got kinda confused. i was not sure if i was suppose to or not but i Upgraded the MP3' firmware. well after it was finished, and i removed or unpluged the MP3 USB from the computer like it says. right after i did, the MP3' screen automatically was black! like as if the battery's dead or it's shut off. i tried to turn the power switch on but there's still nothing on the screen. then i tried to open it on the computer but the computer doesn't or can't even read nor recognize the MP3 device at all. so i was wondering that did i might've caused damages or have corrupted any of the files, contents, or system datas because maybe the upgraded firmware is not supportable. is there a way to re-formated or convert it back to the original firmware? if there is, that's really great! but first i have to figure out if i will be able to turn the power on OR if the computer can even read/open the MP3 device because i've already tried to open it many, many times by using the AC Charger & also the USB Cable. well the point is 1st how to ''turn the power on'' to open AND 2nd how to re-installed back to the original or previous firmware/system. PLEASE do let me know if it's still playable and possibly how to fix it soon. i really, really hope you experts have the solutions to my problems.. (otherwise my BF who got the MP3 4 me will be really Bo!L!Ng-m@d at me. ^_-) thanks alot...i @ppreciated it!!!
  • 593 Answers
My suggestion is to go to the Manufacture's site and look for a FAQ on your problem or contact their Customer support and see if they can help you. Not knowing which brand name and model you have we can't be to much help. Some Manufactures have a great support site on the web, others make you submit a claim to help you. But, I do believe it can be straightened out and put back in working order. .
Posted on Jan 31, 2010
  • Thermo King
    Thermo King Jan 31, 2010
    I found the manufacture site and a manual but I do not know which player you have. But try this - Turn the player on and then press the play button for 5 - 6 seconds or until the welcome screen appears. After the Firmware upgrade the player has to be reset this is how you do it I think. see the site here.
    http://www.bayconsumer.com/BCI/Support.h...
    http://www.bayconsumer.com/BCI/Home.html
Try upgrade procedure again when turn the power switch off.
Posted on Jul 14, 2010
  • hzhou6310 Jul 14, 2010
    I have exact problem as you did. After I turn off the the power switch and did a upgrade firmware procedure, I unplug the USB cable, turn back the MP3 power to On, hold the play button for more than 5 seconds, the player is back to work. I lost some of the previous recorded songs though. So back up your file before any firmware upgrade.
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Tip
What to do when you can't play film or video.
Hi. Thanks for looking.
I have a friend who had this problem just few days ago.He inspired me to write this. What do I do when somebody just gave me film a DVD rip or Xvid some Dvix video in .avi format and it just won't play on my computer? This normally happens after you returned your PC to factory settings or formatted hard drive and got fresh operation system.You can probably hear sound but no picture at all.
  • This means that you are missing codecs on your machine. Codecs are simply talking little programs that tell players how to read video files. There will be different codecs for different operation systems.
So if you have that problem this tip is for you.
  • When using Windows XP please follow these steps:
  1. Go to this website---> http://www.xpcodecpack.com/download
  2. Click on the download link once your on the website and yourdownload should start immediately. Choose to open the file once you downloaded it.Your installation should only take a minute. Once you're finished with installation restart your computer and you should be good to watch your movie.
  • When using Windows Vista please follow these steps;
  1. Go to this website----> http://www.free-codecs.com/vista_codec_package_download.htm
  2. Click on the download link and choose to save file when prompted. Once download has finished go to folder where it's been saved and double click file to start installation. Once installed restart your computer. You should be good to watch your film once restarted.
  1. Go to this website---> http://www.windows7codecs.com/
  2. Once on website click on download link on the left. Choose to save the file when prompted. Go to the folder where you file's been saved once download has finished. Lunch setup file. Once installation is finished restart your PC. You should be good to go when you start your machine again.
Thanks for reading. I hope this helped you if you had this problem. Feel free to ask questions on FixYa. We are here to help you.
sound but no video, video won't play, new film will not work, player problem
on Dec 12, 2010 | Computers & Internet
Need Good & Free test and read/write surface scan tool for a Fujitsu MHT2040AH.
Try the ultimate boot CD, there you can use may hard drive diagnostic utilities, perhaps Test Disk will suit your needs, here;s a link
http://www.ultimatebootcd.com/download.html
Hope that helps
Christopher
May 17, 2012 | SimpleTech Simpledrive Computers &...
No sound on my pc!
step 1: check with the speakers on another computer to ensure the speakers are working fine.
1. Insert the CD-ROM titled 'Fujitsu Technology Solutions Drivers & Utilities CD' that came with the computer into the DVD tray and close it.
2. The Drivers & Utilities CD will start automatically.
3. Click on 'Driver Installation' option.
4. Click on INSTALL.
5. After the installation process the computer will automatically re-start. If not, for safety reasons (to not misinform/corrupt the information on the registry) restart the machine manually (Start Menu - Shut Down).
If you receive a message saying 'Found New Hardware Wizard' during the Drivers installation (Automatic recommended), ignore it and leave the Drivers & Utility CD to finish the installation. The D+U Setup is will detect the computer's hardware (it will not detect the drivers of any external devices you may have) and install the drivers needed. After you re-boot the machine you may get the Found New Hardware Wizard again, this will be your Monitor being detected, follow the on-screen instructions to install it properly (if you have a driver's disk, provided with your monitor or any other external device that you have connected, use this when prompted)
Jul 01, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I mainly use Yahoo Messenger and would like to know if and how I can use the Life Cam mode to chat to my correspondents and do they have to have Life Cam software too? Do the same the same criteria apply...
They do not have to have lifecam mode to chat with you. Regardless of what type camera they use yours and theirs has have the Audio & Video setup properly.
See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Nov 11, 2009 | Microsoft LifeCam VX-3000 Web Camera
Wont work with new msn
Unplug the webcam - plug the webcam back in
Open msn
Show Menu > tools > audio &video set up, - run through audio > Next - set your webcam as default and it should be running - adjust settings > Finish
Aug 09, 2009 | Microsoft LifeCam VX-3000 Web Camera
How to insall driver for graphics & audio ?
its very easy my friend, you are going to use its disc utility by your presario cq50c-106au, all the software drivers of your laptop are there.. from the chipsets, graphics card, sound, USB & etc... always follow its instruction to install the existing device that are not functional. That Disc Utility is Autorun you its not hard to install all the drivers, just read it.. i know you can understand all the setup there... good luck!
Jul 12, 2009 | Compaq Presario Notebook
I cant connect to sound system
Normal 0 After you install Skype and have it operational with your ID. Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Jan 19, 2009 | Computers & Internet
Just installed nero 7 software on my comp. and really messed up all my music files. all my saved files have lost there names & are know numbered tracks of nero media type. Same applys to media i...
hi sir,
by default, you have a music player installed on your system or maybe using windows media player before nero 7 was installed, unluckily, when you did installed your nero 7 it has it's own music player. by the time nero finishes the installation, nero prompts you what media types you are using, by default, nero had selected it's own files types...thats why your music compilation and playlist messed up.
in order to get things back, just right click any music files you have, go to properties, click change for types of file then select the application you want play with your music.
Sep 04, 2008 | Computers & Internet
I need help
I had the same problem
What I did was:
1. click on "tools"
2. then click on "Audio and Video setup"
3. follow the setup exactly
4. when you get to the video setup click on the name of your webcam from the drop down menu.
5. then finish the setup
If this doesn't work then I'll see if I can help again ^^
RiaYerKnoo@hotmail.com
Hope it helps
May 30, 2008 | Computers & Internet
1,399 people viewed this question
 Grubhead
Grubhead
