Question about NEC MultiSync LCD1765 17" Flat Panel LCD Monitor
My computer monitor keeps going to standby - NEC MultiSync LCD1765 17" Flat Panel LCD Monitor
  • NEC Master
  • 13,433 Answers
There are 3 possible causes
1. cables are not connected properly
2. computer is not turned on
3. computer is not working, its not starting up, and the issue has noting to do with the display. Please take your computer to a professional repairer or get someone to come over to sort out the issue.
Posted on Jan 31, 2010
Testimonial: "appreciate the help"
  • NEC Master
  • 2,517 Answers
Please go in control panel then click power option. Change the standy by time from there then appy and ok. And use it. Hope you naver face the problem in future.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Screen keeps going black like timing out but monitor remains on
Hello there,
Make sure that the connection between your computer and the monitor is secure both at the computer and at the monitor. When you monitor goes into standby, it is losing its signal from the computer.
I hope this has helped! Thumbs up are much appreciated!
May 07, 2011 | Computers & Internet
Keeps going onto standby after 1 min i think its a problem in the setting its a p/bell 19" flat screen
Yes its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 22, 2009 | Computers & Internet
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
If I Come Out Of Standby, Gateway FPD 1830 flickers, then black
It's a bad back light inverter. These models are NOTORIOUS for them. It's a simple fix for a technician and not very expensive. I fixed mine about 2 years ago and it's still going strong.
You can purchase replacement inverters and if you're handy with a screwdriver you can fix it yourself.
-=/ Daft Tech /=-
Feb 15, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor keeps goin in to standby
If the Display shuts down after you see a BenQ logo at startup but power LED remains on,the problem is with the Invertor board.Transistors 2SC5707 are known to be defective with other related components.You can try replacing if u are technically able and willing.
Samir.
Sep 14, 2008 | BenQ FP71G 17" LCD Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Standby mode
Check the video connection the video card. You can try another monitor to see if it does the same thing. The video card could be bad.
Jul 15, 2007 | Hyundai ImageQuest F770D 17 in.CRT...
NEC MultiSync LCD1765 17" Flat Panel LCD Monitor Logo
295 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
