Question about HP Compaq nc6000 Notebook
DriveLock Hey I Have a Harddrive from a HP NC6000 (the computer is broken), but the HD won't connect to my computer using a USB-cabinet because the drivelock is enabled.. Anyone know how to disable it?
  • 1 more comment
  • Ida Nyland
    Ida Nyland Feb 19, 2008
    Nevermind, I manage to unlock it..;)
  • Ida Nyland
    Ida Nyland Feb 26, 2008
    That had nothing to do with it at all.. btw: I said I managed to unlok it.. I found another computer in my big pile of crashed computers that worked so I managed to unlock the drivelock.. and, no, the disk was not broken... just locked...
  • Anonymous Apr 15, 2008
    How bout enlightening everyone and tell them how you unlocked it Einstein
  • 100 Answers
I think ur hard disk have problem.Better to take from nearest Hp service centre or complaint lock to this web address.
www.hp.com/support
Note: If u have warranty then only complaint lock it.
Posted on Feb 26, 2008
What does configure drivelock passwords mean?
Drivelock is a security feature that allows you to password protect a harddrive. The big feature here is the password is actually on the harddrive itself and if the drive is moved to a different system you will need the password to unlock it there too. It should be noted that password recovery for this is not an easy task. So don't lose the password :-)
Jul 13, 2014 | HP Compaq Evo Notebook N600c
How do I replace a NC6000 laptop lid catch?
HP Support > HP Compaq nc6000 Notebook PC > Manuals download page > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodSeriesId=367367#3
Click on -
HP Compaq nc6000 Notebook PC - Maintenance amd Service Guide
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
(PDF file doesn't show until it is fully downloaded)
This is a temporary download. If you want to save it to your computer there is a way.
This way you can copy it off to a CD disk, and after checking to make sure it is a good copy; then delete from computer to save harddrive space.
http://www.insidemylaptop.com/replace-web-camera-in-hp-compaq-6730s-6735s-notebook/
http://www.insidemylaptop.com/disassemble-hp-compaq-6730s-6735s-notebook-remove-cooling-fan/
http://www.ebay.co.uk/sch/sis.html?_nkw=HP+Compaq+nc6000+Laptop+Lid+Catch+Latch+Clip+
Regards,
joecoolvette
Mar 09, 2013 | Computers & Internet
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
I need instructions how to remove hard drive
Use the camera function on your cell phone; take picture of all cable connections
disconnect all cables to your computer
disconnect thumbscrews/screws holding computer cabinet shell at the back of computer
slide the cabinet shell forward exposing chasis frame. Lay computer on its side
important: Ground your body to the chassis frame (prevents static discharge damage)
Locate harddrive; with a magic marker ink one side to each of the two plugs and their sockets that are connected to the hard drive.(take picture maybe easer)
This is called making withness marks; it gives you a reference and orientation when you put things back together; the smaller plug is the power plug; the larger plug is for data.
Remove screws that secure harddrive to frame; Ground new harddrive to chasis; replace harddrive.
Nov 24, 2010 | HP Pavilion m7640n PC Desktop
My usb port dosnt recognise my external harddrive and i would like a driver will you tell me were i can get a driver?
For the hard drive, you need to isolate the problem first. The questions are:
1. Have you tried connecting the HD into another USB ports?
2. Have you tried using another USB cable?
3. Have you tried connecting it into another computer?
4. Did you check Disk Management of your computer while the HD was connected?
5. Do you hear a clicking noise on the HD?
6. What kind of driver do you need?
Most external hard drives are Plug-n-Play and does not require any additional driver.
Please get back to me so that I could further assist you.
Have a great day!
Sep 10, 2009 | HP Computers & Internet
I open my laptop i got the message " Drivelock HDD Bay password"
seems like the access to your harddrive is password protected at BIOS level,
try another hd.
if same message occurs, please renew your request at fixya!
Jun 11, 2009 | HP Pavilion dv4000 Notebook
How to disable the drivelock?????
Hi you can disable drivelock by entering system bios and security settings. Please read the notes below and remember you can only do when starting the pc and not when you're restarting.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
✎ DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Hope this helps.
Apr 25, 2009 | HP Pavilion dv4000 Notebook
Re: HDD replacement
If you have replaced the HD - this drive will be completely blank.
Your computer needs an operating system installed.
If you got a system restore CD/DVD with your computer - this is a good time to insert it and follow the onscreen instructions.
Alternatively if you have a windows install disk then this is a good time to install it.
Its also likely that everything on the old hard disk has been lost.
However - At a later date you could try and add it as a Slave disk to see if you can recover your documents etc once you have your machine up and running on the new disk.
Feb 28, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
266 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
