Question about Hotpoint WMA58 Front Load Washer
Where is the filter is - Hotpoint WMA58 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
The filter is located at the rear of the washer.
Remove lower rear cover.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
    New Friend:
Thank you for your help. I had read the same advice somewhere else but needed a second opinion. I have followed your instructions to a T and it appears to have done the job :) Thanks again.
p.S to other people with the same problem, this is coshur advice!
Posted on Jan 12, 2013
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Aug 19, 2011 | Samsung RS2630WW Side by Side Refrigerator
I have an Arlen Ness Big ****** air filter on my 07 FLSTC, I cleaned the air filter, do I have to oil the air filter and if so what should I use?
It is best to oil the filter on most of the after market air filters to catch the finer particles of dirt that might otherwise get through the filter. As to what to use, since I'm not familiar with that particular filter, it depends on what the filter is made of.
If the filter is made of foam rubber, you can purchase both the foam air filter cleaner and the foam air filter oil with which to keep the filter clean and ready for use. Most any place that sells off road motorcycle accessories should have this stuff. If your filter is a cloth type filter, like a K&N, filter, K&N sells both a cleaner and an oil. Personally, on these filters I use a cleaner like Dawn dishwashing liquid. Wash and dry the fillter well and then LIGHTLY spray the filter with the K&N oil. A little goes a long way.
Do not under any circumstances use automatic transmission fluid to oil your filters. It is a petroleum product and will damage the expensive filters.
Mar 17, 2011 | Harley Davidson FLSTC Heritage Softail...
How much oil should i put in at an oil change on a 2001 monte carlo 3.4
Hello, this is the oil capacity of your vehicle.
I hope this info is helpfull
  • with filter change
4.1 liters
4.3 quarts
  • without filter change
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
with filter 4.3 quarts
without oil filter 4 quarts
Oct 08, 2010 | Chevrolet Chevy Cars & Trucks
Where is cabin air filter location
Hi if you have the 3.8 then follow these instructions.
Hi
  1. Left sound insulator panel.
  2. HVAC air filter access cover.
  3. Pull first filter out using filter tab. Filters will bend to clear accelerator pedal.
  4. Pull the second filter out using tab.
  5. Pull the third filter out using tab.
Install or Connect
Important
  • When installing the filter care should be taken so that the filter does not become dislodged from the channel inside of the HVAC module.
  1. First filter in case. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
    • A long thin bladed screw driver may be useful in lifting the filter parallel to the HVAC module.
  1. Engage the second filter in the tab of the first filter and slide it into the remaining channels of the first filter.
  2. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
  3. Engage the third filter in the tab of the first filter and slide it into the remaining channels of the second filter.
  4. Fold the second filter tab down and the third filter tab up and over the second.
  5. HVAC air filter cover.
  6. Left sound insulator
Sep 17, 2010 | 1998 Buick Park Avenue
Tranny Filter
A lot of auto parts come in the form of a filter which is designed to remove impurities and foreign objects from a stream of gas or liquid. A typical car employs an oil filter, a transmission filter, a fuel filter, and an air filter. However, there is yet another type of filter which is least common to car owners. The cabin air filter, also referred to as the passenger compartment filter, the pollen filter, the dust filter, or the interior ventilation filter is inherent in vehicles manufactured in the 80�s. More and more vehicles are now equipped with cabin air filters, but what exactly is a cabin air filter? The cabin air filter is tasked to eliminate almost all of the airborne elements that come with the air that enters the passenger compartment. It is guaranteed to enhance the quality of the air that goes around the passenger�s area. The cabin air filter is attached under the dashboard, behind the glove compartment or in the engine chamber. Your factory cabin air filter may be worn and torn with use and time, which is why an aftermarket Chevymag-glass_10x10.gif cabin air filter replacement is manufactured. The Chevy cabin air filter replacement is designed to ideally replace your factory cabin air filter which is created to top the performance of your old one. The Chevy cabin air filter replacement is ideal to use because it helps purify the air and remove particles that might cause the passengers allergic reactions. It is highly beneficial not only to the car occupants, but also of the car driver so that he will not get distracted from controlling the maneuvers of the vehicle operation.
Dec 14, 2009 | 2005 Chevrolet Equinox
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Hotpoint WMA58 Front Load Washer Logo
371 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
