Question about Refrigerators
Have an LG american type fridge freezer and need to change the water filter for the first time and don't know how to
    President:
  • 1,218 Answers
Good day,
Grasp the filter firmly and turn it counter-clockwise until it releases.
Some water will spill so hold a small bowl under it.
Install the new one in reverse order. Pushed up turn clockwise until it seats.
It will take a while to purge the air out of the system, so be patient.
Posted on Feb 01, 2010
  • 3,740 Answers
They are simple to install, and can be installed on any model refrigerator. They snap / connect into place in the water supply tubing located behind the refrigerator. Many filters use simple compression fittings that are a breeze to connect. The in-line filter kit comes with directions and the fittings to install it. The filter should be changed about every six months because it becomes saturated with gunk.
For a first time filter change all you should have to do is:
1. Turn off the water supply line
2. Unscrew the compression nuts on both ends of the filter and remove it.
3. Take the compression nuts off the new filter (not used as the old compression nuts still in place should be fine)
4. Insert the water line in to each end of the water filter.
5. Tighten both compresson nuts (one on each end of the water filter)
6. Turn on the water supply
Note: There is a chance that your Ice Maker will skip a few ice making cycles until all of the air is purged out of the new filter.
7. Sit back in awe as to how easy it was to change the in-line water filter :)
Take care and thanks for using Fixya!
Posted on Jan 31, 2010
3 Suggested Answers
  • 37 Answers
SOURCE: Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Where is water filter??
You have to check if it has a pipe that you connect to external water supply. The filter is connected to this pipe.
Jul 28, 2013 | Refrigerators
Location of water filter on lg fridge freezer
Jul 22, 2009 | Refrigerators
Need instruction manual for lg american fridge freezer --grl207tuja
having a problem american lg fridge with the water supply out the front of fridge, how do i get it working ?
Mar 22, 2009 | LG Refrigerators
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a water issue with an american style fridge freezer .The water is fin e going into fridge ,but the water and ice is tainted when discharged from the freeze . Something in...
If it is a new fridge or just hooked up the watter for the first time you need to cycle the ice a couple of times. What the coler is is charcal from the filter. Discard the firs two baches of ice then it will be fine.
Dec 16, 2008 | Refrigerators
Filter status, display help
This is normal. The light is on only when it's time to change the filter. I guess you have already found the filter timer reset procedure in your owner's manual!
Enjoy your new fridge!
Mar 12, 2008 | Refrigerators
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
