Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
  • Washing Mach... Master
  • 3,463 Answers
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 31, 2010
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Hy i have a zanussi excel 1250 jetsystem washing machine,and i have a big problem,when i plug it it and push the start button,it starts normaly,iy takes water but after 10/15 seconds suddenly goes of and...
we can't help you here you have to bring an expert to check the thewashing machine and to find where the short cirrcuit is. he should bring with him a Avometer.
Sep 13, 2010 | Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
My zanussi 1250 fjs.13978w model washing machine keeps skipping through programmes,it still fills up with water and emptys but wont wash through any programmes ive even tried just putting it on a spin only...
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 31, 2008 | Washing Machines
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Feb 17, 2008 | Washing Machines
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
487 people viewed this question
Top Washing Machines Experts
