Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Acer 2032 w will not stay powered on
When I start up the blue light goes on and the word ACER comes on the screen and then it turns off and then the loop starts. Over and Over
Also I noticed that the green light on the poser pack 18v 4.17 amp also flickers HELP
If you can splice wires, this will fix it. First beat the old Acer power supply to death. (God, that felt good) Then cut the wire off the old brick and splice it onto a laptop power supply that's rated at 18 or 19 volts @ more than 4 amps. Dell uses them and I used one from an HP dv2000 that cooked itself to death. The Monitor runs on less than 3 amps and is quite happy at 18 or 19 volts. By the way, the white wire is positive and the black wire is negative. Don't worry about those four pins on the plug. If you look on the case of the old brick, you'll see that the pinout is quite simple - 1 and 2 are positive, 3 and 4 are negative.
Posted on Mar 15, 2010
Have had the identical problem with 2 other Acer AL2032w monitors. That is, they will power up, remain on for a short period of time, then shut down. In both cases, the light on the power adapter goes off. I suspected a problem in the monitors themselves, but just for the heck of it replaced the power adapter brick with one from a working monitor, and problem went away on both "bad" monitors. Unfortunately, these adapters are very hard to find. They are a LI SHIN 0219B1875 18V 4.17 amp adapter, with 4 pins in the connector. I have searched high and low for a direct replacement, and while you occasionally find them on ebay, they usually go for $60-$80 plus shipping. If you can track one down, it will likely solve your problem.
Posted on Mar 28, 2009
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer aspire 5536 wont boot up
Hi. My Acer 5536 is not start & the screen is seems block, also the hard light is not working. Only set start light is shinning. What wana do?
Aug 04, 2012 | Acer Aspire 5536-5224 Notebook
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
I turn on my Acer and it starts to load it gets to the full blue screen and then it just stays there with the hour glass? It nevers goes forward. help
Repair the notebook operating system, Some of the file on system might be missing. Try to send the error code which was written on the blue screen. I think this will make the question simple.
Mar 03, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
Oct 25, 2009 | Acer Aspire 5610-4648 Notebook
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Feb 15, 2009 | Acer Aspire 5520-5908 Notebook
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
1,069 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
