Question about Bushnell 4-12x42 Yardage Pro Waterproof Riflescope
Could you advise what type of mounts i need to secure scope to my air rifle,and where can i buy wireless trigger switch.
    Guru:
  • 302 Answers
You need to use dovetail type mounts for your scope try www.Cabelas.com
Posted on Feb 12, 2010
Why is my ant 3x14 nightvision scope switching of by itself after every shot thats been fired. I have to switch it on after every shot thats been fired
The recoil is triggering the switch off. Either the on/off button is over sensitive or the battery gets momentarily disconnected. Check the battery terminals. It might also be part of the circuit rubbing on the scope casing and shorting it.
Jul 03, 2016 | Winchester Optics
How lighten the trigger pull
Sorry, this is I'll advised in this or any firearm. These are set with internal pressure to avoid accidental firing. I am sorry we will not be able to help you with your problems at this time.
Mar 25, 2016 | Crosman Storm XT .177 Air Rifle with 4X32...
How do i mount my 650 laser sight to my bone collector rifle.
Red Laser Sight 650nm Weaver rail mount - Gamo USA
www.gamousa.com > Optics > Airgun Lasers and Lights
650nm Red Laser Sight with Weaver style rail mount.
Gamo airgun accessories, spare parts and products ' Gamo ...
www.gamousa.com/category.aspx?catID=4
Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
Dec 25, 2015 | Laser Optics
I have a 'used' Beeman Sportsman 1000 Series rifle (no scope). Have a pellet in the rifle (it's been in there for about a year, heh), I'm moving the lever-near-trigger back and forth but rifle won't shoot...
If your pumping the rifle and you hear air seeping out then the seal on your air chamber is bad or got pushed from where it is suppose to be, you can take it apart and see, its real simple...
Aug 03, 2013 | Beeman SS1000T Sportsmans Series .177...
Trigger repair on crosman nitro air rifle
http://www.gatewaytoairguns.org/GTA/ is good place to start, you will get all the free advice and info you need.
Largest air gun forum, international. Free to join, all you have to do is luv air guns.
Youtube has some good mods but...
This is the best! It's like the Rolls Royce of triggers!
http://charliedatuna.com/GRT-III%20Trigger%20New.htm
Feb 03, 2013 | Crosman Nitro Venom Air Rifle 0.177
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
Why does my 30 yr old redfield, widefield ,range finder accu-trac scope that has operated great for all these yrs, now I cain,t get it hit in the same zone a target. The rifle is clean and operates great...
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Nov 22, 2010 | Redfield Optics
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Elevation is turned all the way up and at 50ytards
this is a common fault with fitting cheep mounts on your rifle,,
a nikon scope is realy for "air rifles" but having sead that there very strong scopes, i have 4 of them all fitted on full bore rifles,,308,(7.62) .303 british enfield, .22-250 and a 357 mag rifle? and none of them have shook apart yet! and i found that on a full bore they do shoot low,,,to get over this problem you could change the mounts to the ajustable type witch is pricy,,or a cheep way out is to pack the bottom of the rear scope mount out with a strip of 35mm film,,(the rear being the end you look throw),you only need to life the rear end of your scope 25th of an inch to rise its point of impact by 6" inchs at 100 yds as the nikon scope is one click (1 thou of an inch) = 1/4 of an inch at 100 yds so 25 thou will raze it by 6.25 inches (- bullet drop!) just undo the scews that hold down the rear of the scope and slip a bit of old 35mm film under the scope then nip the scews back up again and try it out,,,if its still low put in a bit more packing,,,but you can only get about 4 bits of film in before its likley to bend the scope tube!!! mind you with 4 bit under it you will be shooting at the moon??? its much cheeper that ajustable mounts,, all my scopes are packed out like this and they dont creep or slide or loos point of aim even after 300 rounds in a day?
Nov 18, 2009 | Nikon Optics
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Bushnell 4-12x42 Yardage Pro Waterproof Riflescope Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
