Question about Zanussi ZBF360X Electric Single Oven
Why does the light stay on even though the switch is in the off position on my cooker isolation box?
  • Zanussi Master
  • 3,463 Answers
It sounds like the isolation switch is faulty, which can happen, or it it could be connected incorrectly.
I would advise having the switch checked.
Posted on Jan 31, 2010
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
My grill in my Tricity Bendix cooker is not working?
ISOLATE THE MAINS VOLTAGE TO THE COOKER AND GRILL, if it has a plug unplug it.
There is a regulator on the switch, you will need a tester, if this is working and continuity through the switch reducing as you increase or rotate the switch, that's working. Go to the back top a regulator is attached to the chassis of the cooker inspect for exterior damage, if not check continuity it should only conduct in one direction, and not to the chassis, if it is conducting in all , or opposite directions replace the component. You should be able to collect one from a small electrical repair shop.
Hope this is helpful.
Regards
John
Nov 01, 2014 | Ovens
How do I remove the light bulb cover
You don't say what cooker you have. However if your cooker light is at the back either top right side or left, then it should screw off to the left MAKE SURE YOU HAVE ISOLATED THE COOKER FIRST OF COURSE
Oct 20, 2014 | Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
Smeg cooker 8 function model
Hi.
Sounds like you have a faulty thermostat, the contacts could be sticking.
New stat would seem to be called for.
Nov 21, 2008 | Smeg SE399X/5 Stainless Steel Electric...
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Zanussi ZBF360X Electric Single Oven Logo
106 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
