Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
Ice maker not working. Fridge keeps beeping when opened
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hlk;;lhk
Posted on Sep 30, 2010
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Ice maker not working. Water is going to fridge,
heatman101
68tj
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Warm Fridge No Airflow...Control Panel Beeping
i just had the same call today i ordered the damper control because it seems at times more air comes in and than at time like 30 seconds later nothing and the fan is working its not mine fridge but what you can do take the freezer side upper shells off the ice maker on(not necessery but i thought it was easier) and take off the little cover which is covering the damper it has two screws and look inside of the opening and you'll see a damper, turn up the fridge and see if the damper moves and you can turn down the fridge and see if the damper is moving if not you need a damper! good luck
May 20, 2009 | KitchenAid KSSC42FMS Side by Side...
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
862 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
