Question about Sharp AL-1642CS Copier
Sharp AL-1642CS fuser problem
I work for a very small (4-6 employees) company. They have two Sharp Multifunction Printers. One of them, the AL-1642CS, started making a loud intermitent noise. I told my boss that a belt or gear was slipping and they needed to get it fixed before it got worse. It got worse. The noise is basically constant. If you're just printing on the top half of the page, you'll be okay. But it puts a fold in the middle of the page and the bottom half basically doesn't print. I finally convinced them to let me take it home. The noise is the fuser gears. While pricing out a fuser, I learned you can get parts for the fuser itself, and oil. My question is: What, most likely, is causing this? And could the oil solve it? They don't have a lot of money, that's why I'm trying to help. But I could use some help myself. Thanks for your time and assistance.
  • cassiecat4 Feb 04, 2010
    I took the fuser apart, cleaned it, lubed it, noise gone. Now I have a paper jam error. Can anyone tell me where the sensor is? I'm figuring I knocked it out of alignment while cleaning.
  • cassiecat4 Feb 07, 2010
    Okay, fixed the sensor problem. Now, what I thought was fixed, apparently isn't. I guess the sensor keeps the fuser from turning on. I know it's the gears that are making the sound, but why? It seems that the rollers are too tight against each other, making it hard to turn, which would cause the gears to grind. What would cause the rollers to suddenly be so tight?
    President:
  • Sharp Master
  • 1,447 Answers
I have a lot of spare parts this machine.I live in Bangladesh.How can it possible to send you full fuser unite.if your necessary please send me details.your mailing address.I am expert this copier.it is problem heater gear.it replaceble.If I live in Your country it is no matter for me only 10 minutes.But I am bad luck I live in Bangladesh.It is so far.
Posted on Jan 31, 2010
  • Sazeed Computer
    Sazeed Computer Feb 05, 2010
    F user unite have a sensor.It may be displace or broken liver.check it .
What is code H 4
Fuser code the hot part
Dec 04, 2015 | Sharp AL-1642CS Copier
Please Help!!!!!
The fuser has a flag sensor with an arm that the paper hits as it passes through. That arm moves a flag at the other end that hits a photointerrupter. You may have broke this. If so, you will likely need to order it through a dealer.
Feb 04, 2010 | Sharp AL-1642CS Copier
When power is on, H and 4 blink by turns.
your fuser tempature is too low. your lamp may not be coming on. your thermo fuse is bad. your tjermistor is bad. you need a tech to rebuild your fuser
Jan 02, 2010 | Sharp AL-1642CS Copier
ALARM H and 4 keep blinking -alternating
You have a defective fuser unit. H is for HEAT
Jun 25, 2009 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
H 4 flashing on the Sharp AL-1642CS
you have a problem in heater section------it may be bad thermistor -----defective heater lamp------blown thermal fuse------bad lamp connector----shut down the copier and leave it to cool down------clean all above from dirt and toner deposit and check-----lamp----fuse---thermistor by avometer in ohm range.
Apr 08, 2009 | Sharp AL-1642CS Copier
Sharp copier AL-1642CS
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Nov 07, 2007 | Sharp AL-1642CS Copier
328 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
