I have a mzc 66 bought through online. they forgot to keep the ez-pad system... how can i configure my system without the ez pad system
  • renjith_v Jan 31, 2010
    is there any way to configure the MFZ 66 with out EZPads, IMKPs and MODE 3.1. I meant to say that i need to connect the external source to the MFZ and the o/p should get.
  • 3,247 Answers
Looks like as a minimum you need one master ez-pad device consisting of either one of MKP or Mode 1 unit. Not sure if there is any other way of configuring the system.
You should be able to buy the MKP1.0 for around $120.
http://www.avhifi.com/shop/Speakercraft-Multi-Zone-Systems.html
Did you have any other solution in mind?
I believe you can operate the MZC-66 controller in learn mode with a PC and the ez-tool software and may not need the ez-pad but Speakercraft provide you the software only if you are their installer.
You could buy the ERS1.0 unit as a webserver device and use multiple i-phones to work as MODE 3.1 devices. The ERS will set you back about $500.
http://www.speakercraft.com/files/files/file/1031.pdf
Please post a comment to confirm before you rate this solution.
Good Luck
Posted on Feb 01, 2010
  • 19,396 Answers
Hi.
Usually the EZ pads must be purchased separately. They are included only if you purchase a bundle offer.
I quote from manual:
"The MZC-66 System can be controlled using SpeakerCraft EZPads, IMKPs and MODE 3.1s. Keypad configurations vary from system to system and some parts may need to be ordered separately."
Since one key is needed for each channel, this unit may be sold with no pads. Try contacting the seller to ensure no keypad was included in your bundle.
Contact the seller, or call the manufacturer at support number listed on the owners manual to purchase the key pads. Contact is USA (800) 448 0976 Fax (951) 787 8747 International +1 951 787 0543.
Posted on Jan 31, 2010
Tip
What do i need to program a speakercraft mzc64, mzc66, mzc88 ?
This info is meant for all the Speakercraft MZC controllers.
The software used to program the mzc controllers is called EZ TOOLS the latest version of which is 401. This version handles both the IR database versions released in these units.
V313 is the older one and 401 is the latter.
you will need a laptop which runs windows, EZ tools is native to XP but should work emulated under later versions of windows. I have this running on linux under wine with some basic command line mods to allow the com port to be seen by wine, this works well although some of the rendering of graphics looks incorrect but still good enough to use.
You also need a cable with a female 9 pin d sub at one end and a stereo 3.5mm jack plug at the other, use screened cable.
The correct port to use on the back of the mzc is the jack com port not the dsub rs232 port.
There is no way to copy theprogram off a machine, you have to either have the origion project file that works in ez tools or start from scratch with a new file.
If you need to transfer from one mzc to another one if the first mzc unit has failed hardware, you can remove the rom chip which is plugged into the control board located behind the front panel. This can be swapped over to the other mzc and is the identity of the mzc controller.
For making up a communication cable use the following pins..
Pin2 dsub to tip of jack
Pin3 dsub to ring of jack
Pin5 dsub to earth jack
Trust this info helps.
on Feb 28, 2015 | SpeakerCraft MZC-66 6-Zone 6-Source...
SpeakerCraft MZC-66 , all zones just buzz\ need to find a repair person that know and understand this brand
That's is probably the main IC chip got busted already that causes the hum.
Hope that gives you an idea...
Jul 08, 2011 | SpeakerCraft MZC-66 Amplifier
No sound from any of the speakers. The speakers make a tick ticking sound. One room started, then all rooms followed. I have touch five pads one in each room, all touch pads light up when the speakercraft...
Yup, I know what is causing that all right.
http://calgary.kijiji.ca/c-buy-and-sell-electronics-Speaker-Craft-MZC-and-BB-Series-Amplifiers-Repair-Service-W0QQAdIdZ229607818
I will fix it so it never happens again.
Jan 09, 2011 | SpeakerCraft MZC-66 Amplifier
Looking to have one imput play through all 6 zones using a single keypad
simple to program the single keypad to initiate all zones on a single source at a pre set level using the ez tools software
Nov 26, 2010 | SpeakerCraft MZC-66 Amplifier
One of my mxc 66s ?
CHANGE THE BATTERY OF YOUR REMOTE
Jul 06, 2010 | SpeakerCraft MZC-66 Amplifier
57 people viewed this question
 Grubhead
Grubhead
