Question about Samsung Digimax S700 Digital Camera
Samsung digimax S700 battery problem
After some 10 pics it indicates a low battery and shuts down. Still I test the battery (duracell) and they are still full.
  • 668 Answers
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Posted on Jan 31, 2010
My samsung s700 camera wont turn on its beep three times but wont turn on
try charging the battery or using a new battery. if that doesnt work you should probably send it in to be looked at.
May 04, 2011 | Samsung Digimax S700 Digital Camera
Samsung digimax s700 gives 3 beeps and turns off
The Samsung digimax takes standard AA batteries (but you already new that). The beeps sound like a flat battery warning.
A lot of reviews of this camera note its very high drain on batteries. Are you using good quality AA batteries (for example Duracell M3 or Energizer lithiums)?
If you are trying to run it with "very inexpensive" alkalines (or worse yet - common zincs), then you may proceed directly to flat battery warning, as they cannot provide enough sustained current to run it.
Feb 28, 2010 | Samsung Digimax S700 Digital Camera
Wont take a pic and it hasd a flashing red eye
Hi kv,
Normally that would indicate the flash capacitor building enough of a charge to trigger. If the batteries are getting low, this can take a while. The camera may even shut itself off.
Make sure you have good fresh batteries in your camera.
As an alternative, try turning off the flash completely and trying it. That will either confirm it, or make me look like an idiot.
Best regards
Mike
Dec 19, 2009 | Samsung Digimax S73 Digital Camera
Is it the problems of batteries?
rechargable batteries are the way to go with a digital camera... mine just eats regular ones
Jan 03, 2009 | Samsung Digimax S500 Digital Camera
Software
Here you go. If this doesn't come up,, just google Samsung s700 download and you should get it.
http://www.samsungcamera.com/popup/download.asp?prj_uid=543&prol_uid=1870
Sep 26, 2008 | Samsung Digimax S700 Digital Camera
Autofocus not working
Are you depressing the shutter button half way prior to snapping the shot you want. Also check to see if any of you setting are changed...if it's on auto and you still are have the same problem then your lens could be dirty.
Apr 02, 2008 | Samsung Digimax S700 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S700 Digital Camera Logo
333 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
